Samsung Plasma Display Model SP-S4243 Model code SPS4243X/XAA Type No cd42s7 Serial No B18M3CML504628A Switch on TV turns on (blue light around switch) blinks then turns off. No sound, no video.
I have a Samsung Plasma TV (SPS4243X/XAA). When I turn the TV on, the picture fades to black after about 1 minute. I can turn the TV off and back on and it fades after about 5 seconds. What is wrong?
Fault to its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 03, 2015 | Samsung Televison & Video
Power seems to work but screen won't turn on . It makes a clicking noise and it seems to turn power off and on. Samsung plasma 50" Model: SP-S4243
What your looking at is a power Supply unit go to vancebaldwin.com get the Replacement unit and you will be fine.
Oct 13, 2012 | Televison & Video
I need owners manual for my Samsung Plasma TV model SP -S4223
Samsung SP-S4243 Television
You can download a pdf copy of the manual at the link below. Click on or copy and paste the link into your browser and save the document on your computer. The document opens with Adobe Reader.
http://downloadcenter.samsung.com/content/UM/201105/20110502125808069/BN68-00991J-00Eng_110502.pdf
Nov 12, 2011 | Samsung SP-S4243 Television
Can I replace a broken Samsung 42" plasma PN42B450B1D screen with a Samsung 42" plasma SP-S4243 screen? Are the screens interchangeable?
No, you cant. I have 2 tvs just like yours but the LN model is newer than the SP model tv. I have the same problem, my LN tv has a cracked screen and the other SP model is good
Sep 13, 2010 | Samsung SP-S4243 Television
SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Error Code: Blue light flashes 4 times
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, something simple like a blown fuse inside the TV. The most common board to go bad is the Backlight Inverter Board. It what supplies power to the screen. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jun 08, 2009 | Samsung SP-S4243 Television
Samsung plasma tv shows no picture after cleaning
u may have a bad y-sub board , it is normal on plasmas
Mar 29, 2009 | Samsung SP-S4243 Television
Samsung TV flickering image
You seem to have what is called error diffusion. Either call samsung about it and arange service or do it on samsung.com. What kind of warranty do you have? Depending on your date of purchase you might be able to get samsung to help cover it or pay for it all.
Mar 09, 2008 | Samsung SP-S4243 Television
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
