Question about Mitsubishi WS-65807 65" Rear Projection Television
I cannot get the vertical red lines to move on the right side of the screen on advanced convergence. Any explanation? Thank you in advance Robert
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If convergence will not line up the two STK-392-570 Convergence Chips this model uses need to be replaced.
This is very common in many sets like yours. The chips are mounted on a large metal heat sink on the middle board and a white grease is applied to the back of each to transfer heat. After several years the grease dries out from the heat and one of them fails.
Total parts cost on EBAY for a pair is under 20 dollars and total parts cost if you do it yourself is under 25 dollars.
I have repaired hundreds of these sets and have composed start to finish, step by step instructions for this repair in your set.
They tell you everything you will need and how to do the repair from start to finish.
If you want the instructions give me a "address" and I will send them to you. Also, if you attempt the repair I will be available to assist you during it.
Let me know what you think with a comment here.
SD TECH
Posted on Dec 31, 2010
It has tripple vision and looks like a bow tie.
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Tip
    How to set convergence on Projection TV ' s
    I have given an general explanation on most projection TV ' s
    1. Enter the menu on your TV. Use the remote control and bring up the menu.
    2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    4. Press "Enter." A crosshair pattern will appear on your screen.
    5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    8. Repeat these steps for all colors.
    on Mar 18, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    Can't aline the vertical red and blue on the left
    The Convergence circuit has failed. It is recommended that a professional do the job.
    The Convergence IC's need to be replaced.
    It will be a STK393-110 or a pair of STK392-570's.
    Hope this helps,
    skyassoc
    Jul 16, 2009 | Mitsubishi WS-65819 TV
    Covergence out of alignment on 1/4 Vertical left side of screen
    You need to manually adjust the alignment:
    On remote, press Menu to get to the main menu
    Then arrow down to "ADVANCED FEATURES"
    Then press "enter"
    Then Arrow down to "CONVERGENCE" and press "enter"
    "Red Convergence" should be highlighted
    Press "enter"
    You now have Green, Red, and Blue overlapping crosses.
    If Red is out of whack, use arrows to align
    To toggle to blue (and back to red), press "VIDEO"
    Then align blue cross
    Once the crosses look aligned, and nice and white, press "AUDIO"
    This will bring up the Advanced Convergence screen
    This is a grid of the same overlapping colors
    You have control over the Red and Blue
    If Green is very out of whack, you'll need a repairman…
    While the "target" is flashing, you can move it around the screen with the arrows
    Place it over an intersection to adjust, then press "enter"
    Now the "target" is steady (not flashing), and you can use the arrows move your color
    When it's aligned, press "enter" again
    Now "target is flashing, and you can go to the next square.
    You cannot adjust every intersection.
    Some areas need to be adjusted via the adjacent intersection
    When you're happy with color you're working on,
    Press "video" while target is flashing to change to the other color
    Repeat the above (blue is much harder to see and adjust for me…)
    When you're happy with the entire grid, start hitting "Menu"
    Each press brings you back out one menu level, until you are out of them
    Once you're used to the process, it should take no more than a minute or two.
    Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
    Mitsubishi VS50805 Serial # 102718 No red in picture
    Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
    http://servicemanuals.vstore.ca/
    Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
    Convergent red does not align
    Convergence amp clearly need to be replaced, STK392-570 Sanyo originals. They are two large multi-pin Ic's at locations Ic801 and Ic802. Also check the small 5 amp pico fuses at F9a04 and F9a05 for open and replace them as well if they are.
    Bill
    Oct 30, 2008 | Mitsubishi WS-55807 TV
    Red Convergence
    http://schematicscom.blogspot.com/
    http://homenol.blogspot.com/
    Visit these sites. Convergence procedure of projection televisions are given in detail.
    Mar 28, 2017 | Televison & Video
    Red convergence will not adjust.
    Replace STK393-570 convergence amp IC = common repair
    for qualified Mits tech............................T.
    Nov 09, 2007 | Mitsubishi WT-42413 42" Rear Projection...
    Open Questions:
    See all Mitsubishi WS-65807 65" Rear Projection Television Questions
    Mitsubishi WS-65807 65" Rear Projection Television Logo
    67 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
