Question about Plantronics 510 Voyager Headset - PLN-510 Headset
How do you turn status light on and off - Plantronics 510 Voyager Headset - PLN-510 Headset
Press and hold the volume up button when turning the headset on.
Posted on Aug 04, 2008
Flutterby fairy charge with charger blinking
STATUS LIGHT will FLASH RED when
charging. Allow at least 30 minutes
for a full charge.
STATUS LIGHT will turn ORANGE,
and then turn off when charging is
complete.
STATUS LIGHT will FLASH GREEN
when the batteries in the CHARGING
BASE are LOW. Replace the
batteries.
STATUS LIGHT will FLASH RED &
GREEN when there’s a CONNECTION
ERROR. Reconnect the FAIRY.
Jan 03, 2014 | Butterfly Toys
Status Light Problem
Is the status light yellow or red? If it is yellow, then check the dust filter cover. That cover might be off or not secure. If the status light is red and blinking, then try unplugging the TV for a minute. If the error doesn't resolve the TV needs service. If it is out of warranty, you might want to open up the set and look for any obvious problems on the circuit boards (scorch marks, soot, bulging or leaking capacitors (look like cylinders on tripods)).
I hope this helps.
Jul 19, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Printer stops when printing should begin with red light in status
There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
Jul 08, 2010 | Samsung CLP 300 Laser Printer
No lamp and a flashing red status light
The lamp has run out of its operating hours which is normally 3000 hrs. Replace the lamp and you will be alright.
May 28, 2009 | NEC VT465 Multimedia Projector
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
Status light yellow, won't power on
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Feb 08, 2009 | Cyberhome CH-DVD 300 DVD Player
Laptop won't start-up
Can you tell me if the status lights on the power adapter and/or the battery turns on? Because you are telling me the status lights only stay on for 30 seconds, this should be a power connection problem.
One other possibility: can you tell me the climate environment of where you use your laptop?
Nov 16, 2008 | Dell Inspiron E1505 Notebook
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
No picture, no status light
This isn't a permanent solution, but it has worked for me. The first time I found out about this solution was when the status light went out on my Tatung. I just left it unplugged and didn't plugged it back in for about a month and a half just to see what it would do. When the status light came back on, I knew if it ever did it again, I could try the same thing. Well, a week ago last Sunday, the status light went out again, so I just kept track of when it went out and when I plugged the power cord back in to see if the status light would come back on. Today when I plugged the power cord in, the status light came back on. That was 9 days. I don't know if it could be less than that because the last time I plugged it back in to see if the status light would come on was around last Friday. So it might have worked sooner. Anyway, this seems to work for me. I don't know what is causing it to lose power in the first place, but at least I know what to do.
Dec 23, 2006 | Tatung V30DMTT 29.6 in. LCD Television
Plantronics 510 Voyager Headset - PLN-510 Headset Logo
60 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
