Question about Samsung SV5000W VHS VCR
MACHINE EATS THE TAPE AND DOES NO EJECT. - Samsung SV5000W VHS VCR
  • 591 Answers
Your VCR deeds a good cleaning (pinch rollers, guyding posts and heads) NOT A DO IT YOUR SELF JOB ask a good VCR tech.
or one of the GUYDING POSTS is defective and is not retracting (more serious mechanical problem)
Posted on Dec 31, 2010
When I put a tape in, it loads, then stops.
It sounds like the machine needs a thoro cleaning especially around the guide pins and tape head. Also make sure that the tape is not being excessively tensioned in the cassette housing. If it happens on more than 1 tape then thoro cleaning of the transport mechanism in the machine is required. You may need to run a cleaning cycle more than once or get it to a repair shop to do it for you. If it happens on all tapes then it is possible that one of the guides has become worn or bent, or the drive mechanism is at fault or the drive belt has become stretched and will need replacing.
Jul 15, 2010 | Sony SLV-D300P DVD Player/VCR
SONY TC-WR550z dual tape deck eats tape and doors won't open I hadn't used this unit in 5 year (it's 13 or 14 years old), and before it worked fine. I went to use it again last month (MJ "Thriller" tape!)...
I don't know anything about the "eats tapes". You can take out your tape fairly easily thought. All you need to do is
unscrew screws on the left and right side of unit
remove the cover
use a flat head screw driver to gently push down on a white lever on the side of the drive mechanism while pushing the eject button
Sep 13, 2009 | Sony TC-WR565RM Single Cassette Deck
Vcr player eats tapes and will not eject casset tape
It sounds like either the take up spool isn`t turning because the motor has failed or there`s something inside stopping the spool from turning or there may be something sticky around the skirt of the video head assembly. All I can suggest is remove the top casing and place a tape in the machine and watch what`s happening, Hopefully, you may find a child's toy or something similar under the cassette or the deck. Those labels that you place on tapes were notorious for coming off and finding it`s way into the mechanism. Ian
Mar 22, 2009 | Symphonic WV806 DVD Player/VCR
Vcr eats tape old samsung blak box
Check all belts. clean the all moving parts
Oct 16, 2008 | Sansui VRDVD4000 DVD Player/VCR
Eats tapes!!
Try using a DV tape cleaner to clean the tape heads first and see if that makes a difference.
Sep 26, 2008 | Canon ZR10 Mini DV Digital Camcorder
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Eating Tape when rewinding in vcr mode
look for a tiny pinhole and insert a pin while powered up to reset the device. if no-go, then the take-up reel needs attention...needs possibly a new or well-cleaned-with-alcohol-swab rubber belt
May 27, 2007 | Canon XL1S Mini DV Digital Camcorder
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Samsung SV5000W VHS VCR Logo
59 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
