Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
When I turn the TV it takes some time to turn on. 4, 5 to six hours. What could be the problem.
  • 101 Answers
The hv would come up and then shutdown with 3 pulses. Monitoring EHT line from flyback at pin 10 of connector BL111 from deflection board to small signal board measured only +15 volts before shutdown. This is normally around +26 volts. according to Tech-Line Found resistor RL044 on deflection board off pin 10 same connector had increased in value to 650K ohm should be 221K ohm this resistor is located under heatsink for vertical IC.
if you are not a tech this is not something you should do. this is one thing it could be.
Posted on Dec 31, 2010
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Have a 1996 318i BMW and cannot find how to change clock setting. The manual is in Japanese!
  • Turn the car on then hold the "Clock" button until the ":" begins blinking -- usually four to six seconds though some take up to a minute.
  • Use the "1" and "10" buttons to set the minutes, "100" and "1000" buttons to set the hour.
  • Press the "Set/Reset" button to set the new time.
  • send me 4 thumbs up
    Jan 23, 2011 | Computers & Internet
    Standby flashing six times
    Just do hard reset on your TV by unplugged it for about 5 hours. Then turn on your TV.
    Jan 18, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
    Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
    And then the problem repeats everytime I turn it on from a cold start.
    I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
    Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
    Bush tv frequently turning itself off
    make sure you have not accidentaly scheduled a power off and on if yes torn off/disable them if not check that your power cable is secure
    Dec 21, 2009 | Televison & Video
    Sony Wega stanby light blinks 5 or 6 times
    When a Sony TV flashes five times, that means that there is an AKB circuit fault.
    Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
    This means that there is something wrong with the video.
    Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
    Nov 22, 2008 | Sony KP-51WS520 51" Rear Projection...
    Power Button Light Flashes six times Chassis# PTV915
    Replace SSB p#313912725871. (Small signal board.) New part #PH3912725871. They also sell a kit PH3912725871-KIT.
    Oct 07, 2008 | Philips 50P8341 50" Rear Projection...
    Sony trinitron kv-20fs100
    maybe theres a cold solder in the vertical section.resolder it.take a lot of care when doing this if you dont have experience.
    Aug 18, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
    Tv turns off but will turn right back on
    Service Manual of KV-32XBR400 shows error info regarding red light flash 2, 3, 4, 5, 6, & 7 times only. Each flash corresponds to different problem in TV. Please check red lighe flash count again.
    Aug 10, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
    RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
    41 people viewed this question
    Top RCA Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
