Question about IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2GB Max RAM
Hi I own a IBM ThinkPad T40 and going to install 2GB RAM. it has right now 512MB on the bottom door and 256MB if I remove the keyboard to get to it. I have Microsoft Windows Vista on it and it just reads the 512MB, So I'm guessing the 256MB is not ment to be removed and is needed for it to start the laptop and doesn't count with the 512MB socket area, and Woundering if I could still install the 2GB RAM Max. I have the Manual of my T40 and it states that 2GB is its Max.
  • Patrick Bridge
    Patrick Bridge Jul 08, 2008
    No the 256MB Reads, PC Doctor 5 saying its a Viking 256MB RAM Chip as what it says on the screen and the 512MB is a kingston
Why the hell did IBM locate the 2nd RAM slot under the keyboard?!
Why don't they just put both in the same place like normal lappy's
=] just sayin'
Posted on Oct 26, 2008
My T40 came standard with 256MB of memory in each memory slot, totaling 512MB of memory. I just got two of the same 1GB DDR 266 memory sticks and tried to install them both. I installed both memory sticks, but when I tried to boot my laptop it @ first it stared to beep, then nothing worked. After that I uninstalled the base memory (the one under the keyboard) and put back in the 256MB memory stick (the original one), and then my laptop started just fine, saying that there was 1.28GB (1GB + 256MB).
Does anyone know why the base memory slot will not take my 1GB memory stick???
Thank u.
Posted on Sep 06, 2008
    Genius:
  • 2,028 Answers
The T40 has two ram slots, you can put a 1g chip in each totaling 2g. If the chip will remove, then it is changeable. Vista needs a minimum of 256 to run, so, when you change BOTH chips to equal 2g it will probably read 1.744g, or it may read the full 2g. If it only reads 1g, then the second slot under keyboard may have malfunctioned. It could also be that the 256 chip is bad and your really only running 512 now. With all that said, in order to achieve 2g, you will need to put a 1g chip in each slot.
Posted on Jul 08, 2008
Cpu upgrade
Maximum memory for this model is 512mb, no cpu upgrade neccessary. 2 x 256mb sticks is OK.
Jan 18, 2014 | IBM ThinkPad A22p 2629 Notebook
IBM T23 wont turn on after adding new RAM
Hi - according to memory suppliers your T23 has the following memory capacity / requirements:
  • IBM ThinkPad T23 maximum RAM capacity: 1GB
  • Your IBM has Two (2) memory slots or sockets
  • Module upgrade PIN count is: 144-PIN
  • The memory speed is: SDRAM 133MHz, PC133
  • The laptop DIMM type for the ThinkPad T23 is: SODIMM, SO-DIMM, Small Outline DIMM
  • Non ECC
If you are meeting these requirements, you may have a defective module.
Also, according to Lenovo's page on the machine:
Memory
The system has 128MB or 256MB of memory standard and can be configured for up to 1GB of addressable memory. Memory options up to 512MB SDRAM SO DIMMs each can be added in the two available slots for memory expansion. The standard 128MB of memory is expandable up to 640MB and the 256MB of memory is expandable up to 768 MB of addressable memory with 64, 128, 256, or 512MB SO DIMMs without removing the 128MB SO DIMM that is standard in one of the internal slots for memory. For customers that need the maximum 1GB to which memory can be expanded, it is necessary to replace the 128MB or 256MB card with a 512MB card plus add another 512MB card in the extra slot. Only 133MHz DIMM memory can be used in this system. The use of 100MHz DIMM memory is not supported in the T23 systems.
This means yo can trouble shoot the 512MB modules individually by installing one of the original 128MB modules and one of the new 512MB modules (for a total system memory of 640MB). If it does not boot, try again with the other 512MB module. This will help you identify a defective module that may be preventing the machine from booting.
I hope this helps & good luck!
Sep 28, 2012 | IBM ThinkPad T23 Notebook
I have Ubuntu 10.10 installed on my IBM R40 laptop computer. Although I installed two 512 MB PC2100 266 Mhz memory to both slots. However the computer only sees 512 MB. When I installed Ubuntu I perhaps...
Well, what a mine field!
I found this;
There are at least 9 different R40 Thinkpad models. Look for a label underneath & see if there's a "Type" number...something like 2681, 2682, etc. Once you find the number, go to the following site & select your model/type from the dropdown menu:
http://www.crucial.com/store/listmodel.asp?cat=RAM&mfr=IBM&productline=ThinkPad&submit=Go
And being a 256Mb standard, that may be all it can handle. The above link is rather old but worth a try.
Hope this helps.
Jan 02, 2011 | IBM Computers & Internet
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Thinkpad T30 2367-23S will not use 2GB Ram Card
noway max is max. buy yourself a 1gb and don't try to beat the system or lose it.
Mar 03, 2009 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T20, Intel Pentium III 700MHz Upgrade to Pentium 4?
Max CPU for IBM T20, 21, 22 is Pentium III FCPGA2 1000MHz (1GHz). Max memory is 512MB (2 x 256MB PC100/100MHz). Max hard disc is 250GB ATA. Newest BIOS is from April 2004 at the homepage Lenovo.
Nov 06, 2008 | IBM ThinkPad T20 2647 Notebook
Hi! help plz!
1) Not sure what you want to do. Return to Win98? You may be hardpressed to find Win98 drivers, especially if you have any newer peripherals.
2) Since a cpu has no mechanical parts, it makes no difference whether it is vertical or horizontal. A cd/dvd drive however may be a different story.
3) If you only have 2 RAM slots that hold a max of 256mb, it stands to reason that you can only have 512mb total. There used to be some software programs that were supposed to have the effect of increasing RAM, but I never had much faith in them.
Oct 15, 2008 | IBM NetVista Intel Pentium 3 1GHz / 256MB...
IBM thinkpad g40..i want to upgrade
To upgrade your CD drive there is a screw on the bottom of the machine that holds it in place. Remove this screw and the drive will slide out. I buy most drives for my customers and shop from Ebay. I've found that there are some very good vendors with good prices and warranties there. Now for the memory. The memory you need for your machine is PC2100, and 1g is the max. I mainly use Kingston or Infiniton. Both of these are good chips, and there are other good chips out there. I suggest that you use two 512mb chips that are the same make. I've found that sometimes two different chips will create a conflict with each other. The memory is located under a panel on the bottom of the machine. For memory I use pricewatch.com If you have any other questions please fell free to ask.
Jul 21, 2008 | IBM ThinkPad G40 Notebook
IBM ThinkPad T40 2373 Notebook Logo
2,085 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
