Question about Imation (01932) CD-RW Burner
I have no instructions for imation slim external dvd recorder & no experience -- I need step by step instructions. Can u help?
3 Suggested Answers
  • 10406 Answers
SOURCE: Imation Elite Slim DVD recorder, driver download
Access: http://www.MajorGeeks.com
and download the "Ashampoo Burning 6" FREE(!) software for creating and burning CD/DVD disks.
Posted on Aug 01, 2010
vishwa14379
  • 191 Answers
SOURCE: Nero Express cannot detect my
completely remove nero first.then try reinstall it after restart.
but not correcting by dat,remove nero and install newer version.
Posted on Nov 14, 2010
Hi, i have the DVD recorder on this link: http://www.imation.com/en-ae/Imation-Products/PC-Accessories1/Slim-DVD-Recorder/ My problem is that when I go to watch a DVD on it, it will not work. The DVD...
You said in your post, "The DVD will be under My Computer, but I am unable to play/watch it."
You will be unable to play any DVD that is located under your computer! Besides, with your computer sitting on your DVD, you are very likely to scratch it! Better start putting DVD's in a DVD tray, or put it away in a sleeve or something similar to protect them from getting scratched!
Apr 25, 2017 | Imation (01932) CD-RW Burner
ASUS SDRW-08D2S-U External Slim DVD-RW : Cannot play burned dvd on home dvd players (Sanyo & Magnavox). Have tried HP dvd+r, Memorex dvd+r, & Melody dvd+rw. This is the message I get when I try to...
what sort of burning software are you using it might be because you have not removed any copywrights
http://mac.majorgeeks.com/download4900.html
DVDBackup is intended to let you exercise your "fair use" rights under copyright law to either "time-shift" or "space-shift" DVD content which you may have purchased legitimately.
An example of time-shifting would be to temporarily store the data from a DVD you rented so as to watch it at a later time after you have returned the disc (and avoided late fees!). An example of space-shifting would be to copy one or more DVD discs to your laptop hard drive so as to watch them while on a long airplane flight. Another way that you could use DVDBackup would be to modify or excerpt sections of the DVD video and audio to create your own movies.
Universal Binary
hope this helps
Jun 04, 2011 | ASUS EXTERNAL ODD SLIM EXTERNAL DVDRW...
My external dvd burner cant be detected by my computer
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 16, 2011 | Imation Memorex Slim External 8X DVD...
Can I transfer my VHS tapes to DVD using my Aiptek A-HD+? I do not have a DVD burner, can I use an external one? I really have no clue where to begin and what problems I might run into. If this is even...
The Aiptek A-HD+ has an AV in mode that can record from sources like VHS,DVD,TV etc. Connect the output from the VHS player ( You will have to use a composite cable i.e RED,WHITE,Yellow cable) to the AV - in of the camcorder. Press play on the VHS and record on the cam. The recording will only be at 640x480 or VGA resolution. Once your video is recorded transfer the video to the PC as you regularly do by copying and pasting to your internal HDD. Use a software such as Nero Vision Express to convert your videos to DVD format and write a DVD. It will take come time as the video will have to be converted from the format the cam records in to MPEG-2 which is the standard compressor for DVD. You can use an external DVD writer , but the writing will only start after the files have been converted. You will need some converter for converting the videos to DVD standard or else it might not work on the DVD player's. There are many converters available online but Nero is easy and just one step, drag all videos and click write it will convert and write the DVD , easy.
Hope this Helps.
Mar 04, 2011 | JVC Video Cameras
I can not get it to recorded
in order to record things you must have recording software
Jan 03, 2011 | Samsung External Slim DVD-W USB Compatible...
Nero Express cannot detect my external imation (52x32x52) recorder. Only image recorder (CD-R/RW) detected.
Nov 14, 2010 | Imation Burn-R CD-RW Burner
Jul 31, 2010 | Imation (01932) CD-RW Burner
New Go.video R6530 put DVD+R disc in shows no disc
you can only use imation or verbatim DVD+R. No other DVD's will work. I use exclusively the IMATION DVD's. Easily recognized by the logo on the disc package, it looks like the old movie reels.
Jun 17, 2009 | GoVideo R6530 DVD Recorder
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
How can i watch dvds ?
You need to buy an external DVD RW, you will be able to watch and record DVD and CDs on your Eee.
Here is a lelection, they start from $40
Cheap ones are usually big, probably bigger than your Eee, here are a couple of nice pocket model
Addonics Pocket DVD+/-R/RW - DVDâ±RW drive
External Dual Layer DVDâ±RW Drive
LG LightScribe External DVD+/-RW Dual Layer Slim
Targus PACMB010U DVD/CD-RW Drive
Let me know if this had been helpful.
Many thanks
Aug 28, 2008 | ASUS Eee 4G Notebook
Imation (01932) CD-RW Burner Logo
405 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
