The heater don't get hot - Heating & Cooling
  • 2,133 Answers
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RVIf it's heating element Check power to that. If power is there, no heat, replace heating element.
Posted on Dec 31, 2010
I replaced both thermostats and both elements in my 5 yr old water heater and I still don't have hot water. What else can I look for to fix?
Check that you are receiving 240Volt across top 2 screws on upper thermostat.
Copy following link for troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Jul 11, 2012 | RELIANCE ELECTRIC WATER HEATER
C9 12
Have someone replace heat senser.
Joe Don
May 25, 2012 | Rheem Tankless Hot Water Heater...
Its not getting hot on a hot wash
Washers don't really heat the water it should be connected to a cold water and a hotter water side if your washer is all the way across the house from the water heater it may take a while for the hot water to get to it but if it is getting water to it on the hot cycle the you have hot water hooked to it. Make sure you have both hoses connected to the right sides. Still no hot water you may have an element going out in your water heater.
Nov 21, 2011 | Zanussi Washing Machines
1998 lincoln town car when i turn the temp to 90 it still wont get hot have changed the thermostat, and flushed heater core but it still won't get hot the AC works great just don't have no heater...
Just a stab at it................see if there's a vacuum or electric operated valve in the heater hose lines.Trace it out.The heater hose goes from the thermostat area at intake manifold thru the heater core,and back to water pump area. don-ohio
Nov 01, 2011 | 1998 Lincoln Town Car
How to replace water heater element will water cme out when you remove element does tank have to be drained
Safest method:
Shut off electricity to heater.
Shut the water valve.
Drain heater to below the level of the element, open hot water valve in house to vent heater to speed draining.
If the element is on top, you don't have to empty the heater.
Remove old element, install new element.
Leave hot water valve open somewhere in the house.
Turn water on.
Once air is removed at hot water valve, turn electric on.
Shut water valve.
Gary
Aug 13, 2011 | Reliance /State Ind. 9002450 Element For...
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
Heater stay hot all the time n cool air
Sorry, i don't understand your question. The heater is suppose to stay hot, that is why they are called heaters.
Jul 14, 2011 | 2000 Oldsmobile Bravada
Led flashes all the time heater won't start
some how the hot and neutral became reversed,i don;t know if it happened when a breaker sparked in the box or what . i reversed the hot and neutral at the input of furnance abd it is working at this time.
thanks for your help
Nov 24, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
