Question about Sharp R-1505 Microwave Oven
The light bulbs ("oven light"
  • Sharp Master
  • 9,098 Answers
If your waveguide cover is damaged, it will need to be replaced.
It provides critical protection for the magnetron and waveguide.
The inside light (unlike the cooktop lights) is not meant to be user replaceable.
You have to remove the oven from the wall, remove the outside cover, then you'll see the lamp on the right side of the oven in its socket on the air duct near the magnetron.
The installation instructions make this much easier. If you don't still have yours, we have those form a similar model here to help you. I hope they're close enough.
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You can order Sharp parts
from the Sears Parts Direct Web site The light bulbs ( or from Encompass here.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Posted on Jan 02, 2011
Light does not come on
Lamp replacement involves removal of the cabinet.
Mar 26, 2014 | Emerson MW8987B/W Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
We have a relatively new (about 6 weeks old) GE OTR microwave--model is JVM1540SP1SS. Yesterday it started "running' even when there isn't any food in there and before we push any buttons. When the...
It sounds like a sticky door switch. There are several switches operated by the door latches to keep the oven from operating with the door open. It's possible someone got a little too rough when closing the door, which can cause misadjustment.
Since the oven is so new it will still be under warranty, though. Why not let GE fix it? You just need to tell them it's not working properly. First call the retailer where you purchased the oven. If they arranged installation they probably also handle service. Otherwise you can contact GE's customer service as instructed in your owner's manual to find out how to handle the repair.
Nov 28, 2010 | GE JVM1540SMSS Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Replace light bulb on the Neff H7871 combined oven and microwave.
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Mar 17, 2010 | Neff H7871 Convection/Microwave Oven
Light under unit stays on
open the oven there are two or three safty switches near door one of the switch is for light if it is short then only light will remain on.by opening door light should come on set the time and hit start light will come again. replace that switch and it will be ok
Aug 07, 2009 | GE Advantium 120 Convection/Microwave Oven
Light fails to operate with door open
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
Aug 15, 2008 | Frigidaire GLMV168K Microwave Oven
Model JVM130G
what brand is this and did the light go on when the door was opened before you changed the bulb?
Jun 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
