Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Can not access the security set up to enable WPA
    Novelist:
  • 125 Answers
In order to change or to the wireless security page of your Belkin MIMO wireless router , please follow these setps
1. Open up the internet explorer in the computer in which you are online and clear the address bar and type in the number 192.168.2.1 and hit enter.
2. You will be logged into the Belkin router setup page .
3. In the left hand side, under the heading wireless click on Security
4. It will ask for a password to login, leave the password as blank and click on Submit, then you will be find the wireless security page where you can change or check your password
Good Luck!
Thanks in Advance!
With Regards,
Prema
Posted on Dec 31, 2010
I want to know how i can make my Linksys Router WRT160N work as access point
By default Linksys router behaves as Access point. On some router you have to enable the wireless function.
So the following to configure the router Wireless Access Point
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts. You can connect as many devices as you wish since it is a access point
Thanks
Vote me If it helps
Apr 26, 2011 | Linksys WRT160N Wireless Router
How can I create a secure code?
IN order for you to enable wireless security on your network you need to access the router setup page where you can setup all the settings for it including the wireless security
So to do that access the router setup page and once there look for a wireless portion on the setup page and from there you will be able to see the place to enable WEP or WPA I suggest you use WPA which is a much stronger level of security that you can use.
Dec 04, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
How can i secure my router?
Access the admin page via it's IP address (by default 192.168.0.1 or 192.168.1.1) under wireless security/ security you should see there an option to set WEP or WPA and the likes... you just have to enable it and type in your preferred key and make sure to save the settings
Mar 27, 2010 | Dynex Enhanced-G Wireless Broadband Router
I have a apple. i want to put a password.. wpa security. how do i do this?? i have searched all over. the set up cd is only for pcs..
you want to put a password on wpa security...
here's what you do, actually you are going to open the firmware of your Wireless Router.
Open Internet Explorer, at the "search engine" just type the Gateway Address (192.168.x.x) then ENTER. After that will asking for Login: admin Password: admin __ this time your on the firmware of the Router. This time will appear and select for putting a password on wpa security. Hope this might you the steps. Good luck!
Aug 05, 2009 | Trendware TEW-432BRP Wireless Router...
How do I put an encryption on my linksys router?
Securing your wireless network is a simple process, which generally does not require a lot of time. This can be done by:
  • Enabling WEP or WPA on the Router
  • Enabling Wireless MAC filter on the Router
  • Disabling SSID Broadcast on the Router
NOTE: The wireless security modes available may vary depending on the model of the router and wireless adapter you are using.
Enabling WEP on the Router
Wired Equivalent Protocol (WEP) is a type of wirelesssecurity which does not change. It provides comparable confidentialityto a traditional wired network. There are two types of WEP you canchoose from:
a. WEP 64-bit: This type of WEP consists of 10-hexadecimal codes. To enable WEP 64-bit, click here.
b. WEP 128-bit:This type of WEP consists of 26-hexadecimal codes hence it is moresecured compared to WEP 64-bit. To enable WEP 128-bit, click here.
Enabling WPA on the Router
Wi-Fi Protected Access (WPA) is a type of wireless securitywhich is dynamic in nature. Meaning, it changes depending on the timerenewal you will specify. Hence, WPA is more secured compared to WEP.
  • Temporal Key Integrity Protocol (WPA-TKIP) – utilizes a stronger encryption method and incorporates Message Integrity Code (MIC) to provide protection against hackers.
  • Advanced Encryption System (WPA-AES) – utilizes a symmetric 128-bit block data encryption
To enable WPA, click here.
Enabling Wireless MAC Filter on the Router
Wireless access can be filtered using the MAC address of thewireless devices transmitting within your network’s radius. You caneither permit or prevent specific wireless computers access to yourwireless network.
To permit wireless computers to connect to your wireless network, click here.
To prevent wireless computers to connect to your wireless network, click here.
Disabling the SSID broadcast is one way of securing your wirelessnetwork. This procedure will prevent other users from detecting yourSSID, or your wireless network name, when they attempt to viewavailable wireless networks in your area. For instructions, click here.
Jul 11, 2009 | Linksys Wireless-G WRT54G Router
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I dunno ow to secure my connection with my edimax router
You can read more about WEP and WPA in the following links:
This article explains how to configure WEP/WPA-PSK/Access list on NETGEAR Wireless router (also applicable to access points).
Note:
  • You can configure WEP or WPA. But you cannot enable both at the same time.
  • You can configure Access list and also enable WEP or WPA for additional security.
  • After you enable wireless security features on the router (or access point), you must configure your wireless clients (wireless computers) with matching settings. Your wireless clients will not be able to connect unless you configure matching settings.
  • Its recommended you enable these wireless security settings from a computer wired to the router (or access point).
Configuring WEP:
  1. Connect a computer to any one of the four LAN ports of the NETGEAR router.
  2. Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1 (by default, refer to your product documentation ti determine the default IP address.) in the address bar and press Enter.
    The Login window will be prompting for a Username and Password. The default Username is admin and the default Password is password
  4. Under Security Options, Select WEP (Wired Equivalent Privacy)
  5. Select Authentication type as Automatic and Encryption Strength as 64-bit (or 128-bit) - You must later configure your wireless computers with the same setting.
  6. Select Key 1 and enter any 10 hexadecimal digits - any combination of 0-9, A-F (26 digits if you selected 128-bit as the encryption strength) and Apply the settings. Please note down these values - You must later configure your wireless computers with the same setting.
Apr 27, 2009 | NetGear WGT624 Wireless Router
Wireless security via MAC address
I would enable WPA encryption and keep the MAC security on. Even though no other computers can connect due to the MAC security, without the encryption your network still looks wide open and it will tempt people to connect. At least if they see there is some sort of encryption on they will not even bother with trying to connect to it.
Feb 25, 2009 | NetGear RangeMax WPN824 Wireless Router...
Security connectivity issues
is the PC connection you're able to maintain once upgraded to WPA a PC that is physically connected to the router? if so, that would make sense because WPA (and WEP for that matter) are only wireless security protocols and have no protections for hard-wired connections.
In order to convert your system to WPA security, you must first make sure all of your hardware is WPA compatible (that isWPA Drivers are available for it).
For your PC wireless connection, if you're running Windows XP you can go to the microsoft website and download the WPA client. It is available in the Microsoft Knowledge Base Article 815485. install the update and reboot. you will then be able to enable WPA security on your client.
Then you'll possibly need to update the drivers for your hardware for WPA support (router, wireless NIC, etc) if they did not already come enabled.
next you get to configure the router for WPA. you'll want to make sure you're set to WPA with preshared keys (no authentication server required), use TKIP as the algorhythm, and leave group key renewal at it's default value. and of course Select a key that is not likely to be guessed. write the key down as you'll need to configure your NIC using it.
to configure your NIC, once you're in the configuration menu select WPA-PSK for your authentication, TKIP for the encryption mode, in data encryption set it to TKIP, and in the network key put the key you selected earlier.
At this point you should be able to access your wireless router (or other access point). These instructions were kind of generic since i do not have the specific router you're using available to me, but the settings i discussed should be pretty universal when it comes to WPA security.
Jul 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
63 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
