Question about Garden
My John Deere JS30 self propelled, operate from behind lawnmower does not want to start. I have put in fresh gas fuel. ensured spark plug fired when starting, all to no avail. Appreciate your advice! Thanks, Rod
    Problem Solver:
  • 6 Answers
Just guessing but is there a reason you put fresh gas in it. Did it sit a long time with old gas in it?
If you want to see if its a gas problem, take out the spark plug and pour a little gas (teaspoon) in the hole and reinstall the plug and wire. If it tries to run for just for a little while and dies then your problem is something plugging the gas line or in the carb. If gas sat in it for a long period it turns to a green varnish and plugs up the jets in the carb.
Posted on Jan 02, 2011
What kind of fuel does a john Deere BH 25 gas leaf blower use that is a 2 stroke. And what kind of spark plug is used?
Spark plug is NGK BMR7A gap is .025 Fuel is any gasoline mixed 40 to 1 with 2 cycle oil.
Aug 26, 2016 | John Deere Garden
I have a John Deere JS30 self propelled lawn mower I had issues with it running for 15 minutes and then it stops running. Was low on oil. Added oil over the full line now it runs for 3 min and dies
Wayne, correct your oil level to full line, change your spark plug and try mower. If still acting up after a couple minutes, the Gas cap vent may be plugged, remove or loosen cap to see if mower will run longer and better. If no improvement, the carburetor is dirty and needs cleaned or rebuilt.
Lawn Mower Starts Then Stalls
How TECUMSEH FUEL CAP can Give You Problems
lawn mower troubleshooting
HOW TO CLEAN The Carburetor on BRIGGS Stratton Quantum Lawnmower Engines
Apr 03, 2016 | John Deere Garden
John Deere Snowblower 1032 won't start. Obvious solution?
First dump the old gas and put in fresh. Clean or replace spark plug.
Put a squirt of starting fluid in the carb. If it fires the ignition system is good. Do this a few times because there is still old gas in the float bowl and fuel line. When the fresh gas gets to the carb it will stay running. If it did not fire with starting fluid the points and condensor will need to be replaced and maybe the coil.
Dec 14, 2013 | John Deere 826 1032 Snowblower Operators...
STARTED AND RAN ROUGH AND WONT START AGAIN... NO SPARK
Drain gas completely from tank to ensure no water is in the tank, check for spark with spark tester, if no spark shows with spark tester, re check gap on coil, if points & condenser are present, sand down the gap between the points to ensure a proper connection. Make sure to change fuel filter with a high quality John Deere fuel filter and use fresh fuel... Fuel can "go bad" after 1-3 months, if the tractor is/ left outside chances are there is water in the tank.
Nov 18, 2013 | John Deere Garden
21" Troy Built Self Propelled lawnmower engine won't start.
Remove spark plug, clean or replace. Remove air cleaner, clean or replace. Ensure oil is full. 30w. Drain old gas out of tank. Fill with fresh gas with Stabile added. Remove bowl from bottom of carb. clean. Observe bowl screw, see if hole goes thru screw. Clean out. Bread wrapper works nice. Observe float. Float down gas flow, float up no gas flow. Re-assemble, prime 3 times, pull rope 10 times to start. No start replace carb.
Jul 30, 2013 | Garden
Lawnmower won't start
is there spark?does it fire on starting fluid
Apr 21, 2012 | John Deere JA65 Self Propelled Mower
212 JOHN Deere riding lawnmower starts a couple of put puts then quiits. Gas goes in the line and have put on a new spark plug. Still does the same thing.
Good day. Try replacing teh fuel filter and teke note of the direction of flow. Also get yourself a tin of carburettor cleaner and spray everywhere into the carburettor. Hope this helps
Jun 13, 2011 | John Deere 22HP Hydrostatic 42" Riding...
JS30 will start (sometimes) but cuts off within a few seconds. Fresh gas, new spark plug, and air filter have been installed. Cleaned bolt to float.
JS30 has a problem with the cutoff switch. The cable running to the lever on the
handlebar develops slack over time, and can be tightened up by pulling the
cable at the lever end. Manuver the pressed on end through the hole in the
lever til it locks on the point where the cable enters the pressed on piece. This
takes up enough slack to allow the switch to engage when the lever is pulled
back.
Apr 27, 2011 | John Deere A,b,g Tractor Carburetor Float...
John deere 425 mower won't start
The ignition switch module is likely to be the problem,they seem to quit for no good reason.The safety relays and fuses are built into the board that comes with the switch and will most likely fix your problem.
Apr 19, 2010 | John Deere 420,1020,2010,2020,2510,2520...
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
413 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
