Question about Sub-Zero Refrigerators
I have a 4 year old Sub Zero 736TC. The fridge door does not close easily, I have to push it shut. The problem is that the door has dropped and the bottom of the door (away from the hinges) is hitting on the frame. I can see scratch marks on the bottom frame and see it rub against the frame as the door closes. I cannot figure out how to adjust the door. Can you help please?
    Top Expert:
  • Sub-Zero Master
  • 12,962 Answers
You will have to carefully bend the hinges back into the appropriate position. OR you can always get new hinges at this site. Search Over 2 1 Million Appliance Parts
Posted on Oct 06, 2015
  • 112 Answers
SOURCE: sub zero
This means that your unit is unable to dissapate the heat where it is intended to, the condenser unit. Open the top panel and check the condenser unit to see if it is clogged with debris. It will be on the rh side and looks similar to a car radiator. If it is dirty, clean it. Also, check to see if the fan is running that blows through the condenser. It should be running whenever the compressor motors are. If it is not blowing, replace it.
Posted on Oct 25, 2008
lojacksdad
  • 121 Answers
SOURCE: Door is rubbing at the bottom of fridge. Can it be adjusted?
there is a kit that goes at the bottom hinge that will lift the door
Posted on Apr 17, 2009
  • 142 Answers
SOURCE: I want to reverse the hinges.
Only if the fridge is set up for this. Look at the top right corner of the case and see if there is a plastic plug. If there is it is drilled and tapped for the mounting hardware that is being used on the left. Remove the hinges and put them on the right side. The door handle should have the same set up.
Posted on Jun 02, 2009
  • 5 Answers
SOURCE: the fridge will close but you have to pushed
Ya do change the Plastic In Between between the Hinge and the Door .If it Doesnt work try looking at the Hinges they Might Be loose
Posted on Jul 02, 2009
arikrom
  • 528 Answers
SOURCE: I have a kenmore top freezer refrigerator model
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Posted on Jan 03, 2010
How to remove freezer door on sub zero 736tc?
Open drawer all the way, lift door side upward about 1/2 inch and continue to slide off drawer from rail. Reverse this to re-install it. Good Luck
Aug 17, 2014 | Sub-Zero 736TCI Refrigerator With Ice Box
Our Sub Zero 736TC has water that puddles under the vegetable drawer. I've read that I may need to clean the evaporator tube but can't find instructions how to do that. Help?
The drain at the rear of the fridge is possibly clogged. To check: Remove all the shelves and crisper in fridge, remove the lighting diffuser panel you will then see 3 screws at the top of the back panel. Undo these screws and lift the panel up and out. This will expose the drain trough at the rear base of the fridge compartment. There is a small drain hole right in the middle of the trough. I found mine to be completely clogged and the trough was overflowing into the fridge compartment.Use a small wire (I used a twist tie wire) to poke into the hole and open up the drain.This should stop the problem, as any water will now drain to the tray in the base and evaporate.
I also found that the door was really hard to open immediately after it was closed and after I cleared the drain this problem wnet away (I think the clogged drain was allowing a vacuuum to be created in the fridge when the door closed.
Jul 30, 2011 | Sub-Zero 736TCI Refrigerator With Ice Box
Mine is an older (20 year old) built-in sub-zero with freezer on the bottom and fridge on the top and only one temperature control (in the fridge portion). The refrigerator is working fine, but the...
You might have a dirty condenser or possibly a freon leak. Check to see if the fans are running and lights are going off when the doors are closed. You didn't mention what the model number is, that might help.
Jan 18, 2011 | Sub-Zero Refrigerators
My sub zero fridge is leaking water. The drain at the bottom of the fridge is blocked and the water overflows and eventually flows out when the door is opened. How can I unclog this drain. This is a...
use a syringe with clorine bleach to unblock the drain.and check that the door seals are touching all round otherwise you will constantly have a frost problem.
Oct 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
Closing and opening a sub zero door
Maybe I'm not understanding your question completely.. You can open the doors whenever you want - as often as you like. The doors are no different than any other fridge as far as how often you can open and close them. Please clarify if I missed your intent. Thanks!
Jun 17, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a sub zero 650. It is shutting down intermittently... The light is off on the fridge part but not on the freezer part. It seems to still be running but the fridge unit gets warm and the controls are...
This happens to me when the door gets left open...appears there is some energy saver or something...needless to say we all are very sure that the door closes the whole way after throwing away 3-4 sets of food!
Mar 03, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero stopped working after door left open
whe n you left the door open the fridge have a sensor. and turn the LIGHTS OFF. close the fridge let it cool again.
Aug 09, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Door not closing properly
Hi: The Kitchenaid refs. us a gravity close along with the magnets in the door seals. Magnets getting weak seals getting old and what you told me you checked can cause this. The easy fix is to raise the front of the fridge by lowering the front wheels. Pull the grill off the front and find the leveling screws (usually labeled.) Raise the front of the fridge until the doors swing shut with a gentle push. Before you replace the grill make sure the fridge dosn't rock side to side as you want it even. This is what they call leveling a fridge. Not cabinet level. Just sturdy. Hope I helped, Jeff
May 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
326 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
