Question about Honda Landa PG 3500 PSI Pressure Washer
My hot water is not working i have power to relay that is new but it will not send power to my on off switch
    Scholar:
  • 45 Answers
I am a little confused by your question because a PG is a cold water pressure washer. In most mobile hot water machines there will not be a relay. My best guess is that you are talking about a GFCI that is not sending voltage to the On/Off/Burner cam switch. To check this you will need to verify that voltage is actually passing through the GFI. If you can clarify with a model and serial for your machine, I will be able to give you better trouble shooting instructions.
Sincerely,
Aron Kerr
Landa Northwest
800.247.8103
503.255.6508
www.landanw.com
Posted on Feb 13, 2011
Starter relay will not disengage starter new ignition switch new starter when ignition is turned to the on position motor starts relay is removed starter disengages relay socket remains "hot"
the wires at the ignition switch are wrong
the power to the relay should only be hot when the key is in the start position and not the run position
Oct 01, 2015 | 2004 Mazda Tribute
Battery hot wire hot at solenoid but no fire at start switch.Can jump solenoid and it will turn over. What do I look for?
The start switch ? Do you mean the starter relay your jumping the solenoid on the starter and it starts right but when your in the vehicle and you turn the key you get nothing right if this is correct the starter relay is no good when you turn your key in the steering column lock that moves the ignition switch on the steering column sending voltage to the relay then the relay sends it to the solenoid which then powers up the stater motor then it cranks the engine//// so the relay is bad
Mar 31, 2015 | Cars & Trucks
No power going to ignition control module, what would cause this?
Yes, the pink wire to the ICM and from the run/crank relay should have battery voltage in run or start. If not, check fuse 11, a 10 amp fuse in the Fuse Block-Underhood. Also check fuses 38- a 30 amp fuse supplying power to the run/crank relay, and fuse 9- a 10 amp fuse between the run/crank relay and the ECM. All of these fuses are in the underhood fuse block.
Fuse 38-the 30 amp fuse, the power feed for the run/crank relay- will be hot at all times. Fuses 9 and 11 will be hot in run or start. Check for power at the fuses. If the relay is not turning on and sending power to those fuses and to the ICM, and the ECM, (and to the injectors through fuse 16 - a 10 amp fuse), then work back to the ignition switch and the body control module. Wish I didn't have to say that, but yes, the BCM is between the ignition switch and the run/crank relay.
Good luck, Michael.
May 27, 2014 | 2003 Saturn ION
No power to pump..checked fuses relays new pump... no power to pump
The pump relay gets power from two different fuses, then the engine computer grounds the relay to send power to the pump. Fuse 4 is hot all the time and fuse 9 is only hot when the key switch is on.
What part of the equation is not happening ?
Feb 25, 2014 | 1995 Dodge Ram
Chevy Tahoe Intermittent No Crank
I will try to help, powell. Your start circuit from battery to ignition switch to starter-and back to battery. You may need to check every thing here, including the grounds, for a loose connection, or just possibly a failing part.
If only complaint is intermittent starter action, and no other problems with ignition switch, let's assume switch is good, so battery to ignition switch is good. Now from the switch, a yellow start wire goes to the instrument panel fuse block, to "crank" fuse #8 (10 amp), from there a purple wire goes to the safety switch. If manual it is a clutch pedal position switch (simple on/off switch-when clutch down switch is on). If automatic, purple wire goes to Transmission Range Switch on the transm.-in park or neutral the purple wire has continuity in and out of switch.
From that switch, the purple wire goes to the starter relay (under hood fuse-relay center). Now the relay: purple wire in start will energize the relay- wire goes to coil side of relay, and then coil side goes to ground. On relay power side, the power feed is a red wire-and it is the same red wire that initially sends power to the ignition switch. A 40 amp fuse in fuse-relay center sends power to ignition switch, and a splice goes to the starter relay as the power feed for relay. When relay is energized, contacts close, and power is sent from relay to the starter solenoid, again on a purple wire. When solenoid contacts close, starter motor is connected to the big battery cable on the starter.
There is your start circuit. try a new or different relay, try a new or test the clutch switch (or transm. range switch). Buy a $5 test light and use it to check where power is lost when starter won't operate. Hold key in start and check if fuse #8 is getting power. Check the safety switch, with key held in start, the purple wire should be hot. Check if relay has a power feed (pull relay out and check terminals) and if relay coil has a power signal in start. Check the relay's coil side ground. If that ground is intermittent, relay won't work.
When it won't start, use a test light, you should be able to find it.
Good luck.
Jan 10, 2014 | 1997 Chevrolet Tahoe
1997 E350 Eldorado bus passenger heater blowing cold air
There is a separate heater core, like a small radiator, which needs hot water running through it, so when the air blows over it, the air gets hot. It sounds like the diverter valve which sends the hot water to this heater core is not working. It could be a problem with the valve itself, or the relay or switch that controls it, or the vacuum line or device that opens the valve when the switch or relay tells it to open.
Dec 10, 2013 | 1997 Ford Econoline
Hello! I have a 1997 Maxima that has no power to the dash, radio, starter, windows, or basically anything related to the key being in and turned! The interior lights and headlamps work, but they do not...
Sounds like ignition switch problem. But check if you have a maxi fuse or a fuse link that sends power to the switch. There is no relay between whichever one of those sends power to the switch, and the switch itself, it is a straight hot wire- hot at all times. You may have lost power to the switch.
Aug 22, 2013 | Cars & Trucks
No power to A/C Control Switch
pull switch if no power back track to find open if power switch is bad the a/c relay runs the compressor a/c fuse powers relay fuse is powered by the ecm , ecm gets command from control switch, ecm reads all input and powers relay to send voltage to compressor. wire should go back to fuse box and be hot with key on.
Jul 29, 2012 | 2003 Ford Explorer
I have 86 celibrity, electric fan will not work. if i take test light and check where the relay switch is, red wire hot and light comes on, if i turn on ing. switch and take test light to green wire (2nd...
What your doing when you touch the test light to that 3rd wire is actually closing the circuit and powering the fan, like the temperature controlled switch should be doing once the engine warms. That sending unit would be screwed into the cooling system where the water can touch it and most likely is in the radiator lower tank or bottom of radiator side tank. Find that sensor and test the wires for power when engine is hot and fan should be on. You could put a toggle switch on it to activate the fan until you get the proper sending unit/sensor.
Jul 11, 2017 | 1986 Chevrolet Celebrity
Cold Water 25-May-08
I know this may seem a little silly of me to ask but have you checked the filters in the back of water valves to see if they are blocked??
May 24, 2008 | Hoover AL120 Front Load Washer
Honda Landa PG  3500 PSI Pressure Washer Logo
298 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
