Question about ATI Sapphire RADEON X800XL RADEON X800 XL GPU 256MB GDDR3 PCI Express x16 with VGA Output, DVI, TV-O... Graphic Card
Radeon X800 XL AGP Card Installation Error
Hi, can you please help me. I recently installed the above card and after restarting the computer, an error message appears saying that ATI cannot find any installed drivers. I can also see 8 display devices of the same type that is RADEON X800 Series and these devices have a memory and resources conflict. Windows automatically detects these devices and even if I uninstall them windows will install them again.
    Scholar:
  • 40 Answers
You should do a deep uninstall of all of the ati drivers present in your system... here are the instructions.
The "deep uninstall" starts by first uninstalling all ati drivers and programs present in the affected computer computer, remember to remove al ati related programs from control panel's add remove utility, including the whole multimedia center. And finally reinstalling the new drivers.
You should have downloaded the most recent catalyst drivers from ati.
Now proceed with the "deep uninstall" following this directions, taken from somewhere on the internet, thanks to the one who wrote them...
1. Go into the Control Panel and under the ADD/REMOVE SOFTWARE icon uninstall the ATI Multimedia software and/or the ATI DVD software.
2. Uninstall the ATI drivers also found in the Add/Remove section. Once removed, it will prompt you to reboot....do so.
3. When returning to windows, the NEW HARDWARE FOUND wizard will come up and will tell you that it has found a new VGA card and will prompt you for drivers. Hit CANCEL!
4. Now, go to START - SEARCH - FOR FILES OR FOLDERS and do a search for all files and folders using the filename ati*.*
This search will normally give you 3 to 4 files found in your c:/windows directory and subdirectories (including the Windows/System directory). Select these files and erase them. Now go to your Recycle Bin and Empty your bin.
5. Next...time to go to your Registry. Go to START -- RUN -- regedit
Here go to key HKEY_LOCAL_MACHINE -- SYSTEM -- ControlSet001 -- Control -- Video . Here there should be 4 entries. 3 of them are default Windows XP entries and the 4th one is put in by the ATI drivers. Expand each one by one until you see ATI entries. Once found, erase the entire key.
Now repeat the same step above for the ControlSet002 key and the CurrentControlSet Key. Normally, whenever you erase a key in the ControlSet001, XP automatically deletes it in the CurrentControlSet section too. So if the ATI key is not found in the CurrentControlSet section, don't worry about it.
Once all keys are deleted, proceed to the next step.
6. While still in the registry, go to the key HKEY_LOCAL_MACHINE -- SOFTWARE section. Here you should find an ATI Technologies key. Select it and delete it. In that same section, look for an Installed Options key. Expand it and there you should find another ATI Technologies key. Select it and erase it.
7. Still in the registry, go to HKEY_CURRENT_USER -- Software and there you should find another ATI technologies key. Select it and erase it. Once all this is done, close the registry. the registry is now clean. Though you might want to even run a registry cleaner, like the one included in the freeware program CCLEANER, it's very good, can be undone and it's safe enough to use it almost blindly.
8. Close all windows and reboot.
9. When in windows after the reboot the NEW HARDWARE FOUND WIZARD will pop up again. Cancel that. Now find the new ATI drivers that you have downloaded and extracted and run the SETUP file. Once complete, reboot and you are DONE!
Posted on Jan 04, 2009
I'm trying to replace my old ATI/AGP graphics card and install a used ATI/AMD Radeon x800 xL AGP-256mb graphics card into my computer. After installation, the system would not boot up; heard this...
Since that is an older card I will assume that it is previously owned.
Try reinstalling the card and leaving your computer open so you can look in and see the fan on the video card, Use some liquid paper to make a mark on the fan so you can see it, you may need to lay the case on its side. Now plug your computer back in and see if the fan is spinning properly, Also make sure no wires are interfering with it.
Aug 13, 2011 | ATI RADEON X800 XL, (256 MB) AGP Graphic...
So which video card do i need? i have 845gl motherboard . before installing this video card (rage XL 8mb pci) my pc plays videos and most 3d game very (even gta sanandreas) efficiently but now it is not...
The ATI Rage XL 8MB PCI video card is a very old and low power video card.
PCI graphics cards are not as fast as AGP graphics cards so if your motherboard has an AGP slot (it's the slot closest to the CPU and is usually coloured brown) then that would give you better performance.
These days AGP has been superceded by PCI-Express but since your motherboard does not have a PCI-Express slot then the best graphics card for it would be something like this one:
http://www.play.com/PC/PCs/4-/5416296/Sapphire-ATI-Radeon-HD-3850-512MB-DDR3-AGP-8X-Graphics-Card/Product.html
Hope this helps, please rate my answer :)
Chris
Mar 02, 2011 | ATI Rage XL 8MB PCI Video Card PCI
When i inistall driver computer has been restart?
please i dont know what u mean please try explain better, do u mean that the ATI 9250 dint work?
Jul 19, 2009 | ATI RADEONĀ® 9250, (128 MB) AGP Graphic...
I have no display after installing a radeon x800
Make sure you install your drivers for the new graphics card before you actually put it in.
May 13, 2009 | ATI Radeon X800 XT Mac Edition AGP Video...
Computer restarts on game start
Remove all traces of ATI drivers from add/remove programs and reboot before trying to install the newest Catalyst Control Center. The latest - 9.4 - does NOT have your card listed (they list the PCIe version, not AGP).
Recently ATI removed support for many of their "legacy" cards. 9.3 may be of more use to you.
Apr 13, 2009 | ATI RADEON HD 2400 PRO Graphic Card
No display when card is installed
YOUR HAVE EQUIPMENT CONFLICKS WITH THE HARDWARE.
IT MAYBE A IRQ AND DMA ERROR
ROD
Mar 12, 2009 | Computers & Internet
Computer beeps error when ATI X800 XL video card is installed. HP computer with 64 bit Vista on it....
Be sure that your video card fit on you os, as you said its 64 bit. Try to work in bios, or just reformat your sytem.
Nov 22, 2008 | Abit Fatal1ty RADEON X800 XL, (512 MB) PCI...
Need new card, system requirements confusing
Radeon X800 XL is a PCI-E (PCI-Express) card, you can replace it with any current ATI or nVidia video card that uses the PCI-E slot. Since you already have a PCI-E card before, I would bet you already meet most of the system requirements.
Nov 13, 2008 | ATI RADEON X800 XL, (256 MB) AGP Graphic...
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Computers & Internet Logo
127 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
