Question about Samsung ML-2851ND Laser Printer
Paper now jams all the time in Samsung ML-2851. I have tried all the remedies in the manual but paper still pulls to one side and jams in paper tray or single sheet feeder. What part do I need to fix or replace to get printer working again? Thanks.
  • 1,218 Answers
Before loading the paper, you need to hold the stack of paper, and then tap it to make the stack even on all sides. Ensure that the paper adjusters on the tray are positioned in a right manner. Push the stack of paper into the tray until it stops. Never try to force the paper too far in the tray.
Posted on Dec 31, 2010
After freeing a paper jam on my Samsung ML 1750 the On line/error
Frequently a very small scrap of paper is caught in the paper path. Take out all the trays and the toner cartridge. Then look very carefully with a flashlight for the smallest scrap left behind.
May 12, 2010 | Samsung ML 1750 Laser Printer
I have a samsung ml-2010 and the printer light is stuck on red after a paper jam. doesn't seem like there's any other paper stuck. apparently, some folks have said that it's best to take the fuse from the...
It's a very short paper path, you should see a lever near where the paper exits, sometimes that lever sticks, on this machine the red light doesn't go away until you load fresh paper in the tray as well. You can see any leftover scraps when you pull out the toner cartridge, after that any other sensors are hidden inside the fuser assembly, requiring a shop repair.
Aug 07, 2009 | Samsung ML 2010 Laser Printer
Printer jammed - removed jam but paper guide not resetting and on line error remains.
Had the same problem. Make sure you have put enough paper in paper feed tray (more than 10 sheets) and lock paper from sides. Take out ink cartridge and reinsert it.
Hope this works for you ^_^
Jul 17, 2009 | Samsung ML 2010 Laser Printer
Samsung ml 2010 r laser printer
Check your manual, there is a solution there or download the user guide from
this site below or read the information below.
http://downloadcenter.samsung.com/content/UM/200602/20060216163720484_ML-2010_English.pdf
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 17, 2008 | Samsung ML 2010 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
Frequent paper jams.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new ream of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
Nov 04, 2007 | Samsung ML 1710 Laser Printer
Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Aug 23, 2007 | Samsung ML 1651N Laser Printer
Paper jam/lockup
Check to see if the egg-shaped rubber feed roller is cracked. (Pull out the paper tray, it's in the middle at the front on top.) That's what I'm looking for now on the ML-1740. Seems Samsung used cheap rubber for the roller. It should only be a $.50 part if you can find one.
Aug 03, 2006 | Samsung ML1740 Laser Printer
Samsung ML-2851ND Laser Printer Logo
488 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
