Question about Brother IntelliFax-4100e Fax
The ride side of my faxes and copies are black, any ideas?
The scanner lamp is probably bad on that side, it can be replaced if you want
Posted on Apr 15, 2013
  • 488 Answers
Sometimes you may see vertical streaks/black lines on the faxes you receive. Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
to avoid spilling and scattering toner.
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada).
Posted on Dec 31, 2010
4 Suggested Answers
  • 215 Answers
SOURCE: Black line about 1 1/2 inches wide down side of faxes or copies
if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
hth,
razors
Posted on Jan 28, 2009
komguy
  • 2306 Answers
SOURCE: 95% of copy or sent fax black
You need a new cis unit, that is the scan assembly. Some of the pixels are burned out. Exposure settings won't help at all...
Posted on Jul 24, 2009
greg_margo
  • 1959 Answers
SOURCE: Brother Intellifax 1" black line on right in send & copy modes
The most common cause of your problem is debris in the paper feeder. To fix this, lift up the feeder panel and clean out the feeder channel. Sometimes loose dirt or a scrap of paper will find its way in front of the scanner lens. A can of compressed air will usually do the trick here unless it's a smudge of some sort in which case it will need to be cleaned directly with a soft cloth.
Posted on Nov 16, 2009
Black line down right hand side how do i get rid
Open the original feeder of the fax and look for dirt on the platen(thin glass ) glass usually white out or postit glue clean with damp rag or isopropyl alcohol
Good luck
Apr 19, 2010 | Office Equipment & Supplies
HP Office Jet 7410 printer copies, fax are black
If you make a copy and it is black, either the ccd (reader is bad or the lamp is out) either is the end. Take it back to staples if you can.
Make sure you unplug it for about 1 hour and plug back in and try a copy.
Apr 28, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
hth,
razors
Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
Same black line on right side problem
take out your drum unit and make the blue plastic corona wire cleaner on the drum unit is pushed all the way over to right side. see if that helps.
razors
Dec 30, 2008 | Brother IntelliFAX 4100 Laser Fax
FAX received full of black stripes
If you are using upper tray to send the fax than kindly open the fax gently and clean the lens with some cotton and spirit and than try to send the fax you will get the best result. to open the fax unit gently refer the user manual or this open by lifting it up side and you can see the lens inside it so clean the same ok.
Dec 22, 2008 | HP LaserJet 3050 All-In-One Printer
Copy machine won't copy
you will probably have to have all cartridges working.
Aug 04, 2008 | Brother MFC-8220 Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Black pages when making a copy or printing something
Have you tried both drum and toner supplies? cause it sounds like a drum fault, if you have tried a new drum and toner, and it is doing it when printing internal reports, receiving fax's and copying then you have a tecnical issue to do with charge and this would likely render machine unecomical to repair (unless you can find a bad contact with drum on machine). If it receives faxs clearly but copys black then it is different issue (ie optics).
Oct 16, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-4100e Fax Logo
371 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
