Question about Akai Televison & Video
Red light comes on and makes a high pitch noise with no power
    Master:
  • 691 Answers
Sounds like you may have a short in the power supply, if you have electronic experience then check board if not then just replace PS. shopjimmy.com or discount-merchant.com
Posted on Dec 31, 2010
High pitched noise when the T.V. is off. The noise only occurs when the T.V. is off and the red light is on.
Such symptoms caused by damage or problems from the POWER regulator, comes from the transformer noise. usually caused by too high output voltage over 125 Volts. and is caused by other parts in the power regulator has been damaged or weakened, for example. is elco on the part of regulators. like to elco 100uf/50Volt size, 220/50 Volt. you can replace it, here Otocoupler in the regulator.
Aug 31, 2010 | Proscan Televison & Video
SB 800 Speedlight AF red lamp not function
The problem is probably caused by a fault in the main power circuit board, if the red light doesn't come on then you also probably won't hear the high pitched noise as the capacitor charges. Will be expensive to repair as you will need a new circuit board.
Aug 16, 2009 | Nikon Speedlight SB-800 TTL Flash
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Noise
The high pitched noise could be because the vacuum is loosing airflow. does the red light come on on the top? if it does ot emptythe vacuum, replace the cone filter, the secondary filter, and the batting in the top of the machine. also hook the hose to the top of the vacuum to make sure there are no clogs in the hose.
Aug 23, 2008 | Filter Queen Majestic Canister Vacuum
Mother board problem
The noise must be coming from the power supply. The only thing running before you press the power on button is the PSU.
Unplug the power cord on the PSU. Check the back of the PSU for a red slide switch. Make sure it is set for 115v. Than disconnect the main power from the motherboard. Plud in the power cord, (still hear the high pitch noise?). Swap out your power supply.
Mike
Apr 09, 2008 | ECS RS400-A (V1.0) Motherboard
Televison & Video Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
