Question about Pioneer Audio Players & Recorders
On July 3-08 I put a cd in the cd player and my display screen went blank and I cannot get it to come back on. The display screen will work when the front pannel is in the open position,but when it closes it goes out. Please help me if you can. PS:I have a DEH-P6800MP
  • Lucky Boy Jul 12, 2008
    The advice I received did not tell me how to fix the problem with my unit, it just said I had a bad ribbon wire and it was easy to fix at low cost.
  • Lucky Boy Jul 13, 2008
    Thank you for your help but I could not fix my radio myself. Circut City where I bought the radio said they would send my radio off to a repair center to fis it, Once again thank you.
    Brigadier General:
  • 6,966 Answers
Two possible corrective actions:
1. Do a reset. Most versions of the Pioneer DEH-P6800MP Car Stereo has a small recessed reset button. It can only be seen if you remove the front/face plate;
2. clean the little contacts both of the removal face plate and the fixed front of the unit. Use cotton buds and alcohol.
3. remove all power connections (red and yellow wire) for an hour or so. (You may need unlock code if previously enable and or as a security feature).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 12, 2008
    Scholar:
  • 135 Answers
Dear customer
Thank u for ur inquiry
Problem: CD player is operational but there is no display or partial display.
Possible causes:
  1. Burned out back-light bulb(s).
  2. Bad connections to display panel (totally dead or erratic).
  3. Bad solder connections on display panel (some segment work).
  4. Bad power supply (EL panel filament, driver voltages).
U can check the bad solder by looking for any loose wires. do check it n revert back .
thanku
  • 4,472 Answers
The part is about 32.50$ on ebay but It is not very simple to replace it. Are you sure you want to risk further damage and chance wasting 32.50 plus shipping? How old is the player and how much did you purchase the unit for?
Thanks,
Lee
  • Lee A.
    Lee A. Jul 13, 2008
    Yea that is what I was getting to, that is why I asked the questions I did. That is probably what I would have recommended as I worked at a circuit city for over 4 years. You should be set with them.
    I hope you will accept and rate my solution accordingly.
    Thanks,
    Lee
  • 790 Answers
Hi
you have defective ribbon wire!
  • carlos fernandez Jr.
    carlos fernandez Jr. Jul 12, 2008
    thats why you have adnormal display screen in your unit!
    this is easy to fix and low cost..
    Thanks!
My new Kenmore Electric Range, model 790.9419, purchased July 18, 2014...The clock no longer works. I press "clock", the code CLO appears; I set correct time; press START and the display goes blank an
That's an enegy saving "feature" - the ability to turn off the clock. Usually (in most models), you can turn the clock display back on by pressing and holding the clock 10 to 15 seconds.
Sep 17, 2014 | Kitchen Ranges
My dvd playeer was playing fine until I pressed the setup button, from there I went into the screen with 480P, 780P, 1080P Etc.. I pressed 1080P and the screen went blank and I cant even get back into the...
Try pressing the HDMI button on the remote control to toggle the display output to something that your television will recognize. You can also try The progressive button and see if that helps. I am assuming you model is the XD-E500 model.
Jan 13, 2010 | Toshiba XD-E500 DVD Player
My screen just went blank, now player does not work
I have the same problems sometimes. what you can do is to take a straight pin and at the bottom of your zen is a tiny hole. stick the pin in the hole to rest it. It should come back on. Upon coming back on it should say it is rebuliding info.
Jan 03, 2009 | Creative Labs Zen Digital Media Player
Blank/black screen
Your CD drive is bad or its the videocard gone out at that exact moment you had the CD in.
Aug 02, 2008 | Compaq Presario 1200 Notebook
Mp3 blank screen problem
I would recommend that you tried to reset the device if you have not done so..To reset the device preses the power button for about 15-20 seconds..let me know what happens....
Hope this help
Thank You
Computerrep
Mar 20, 2008 | SanDisk Sansa e250 MP3 Player
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Nov 28, 2007 | Classic Electronics CDR201 CD Recorder
81 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
