Question about Everest Refrigeration ESR2
Why is the evaporator icing up - Everest Refrigeration ESR2
    Sergeant:
  • 183 Answers
It is icing up because the defrost heater and defrost thermostat are not working and need to be replaced. Check the continuity of the defrost heater first before replacing it. If defrost heater tests okay, just replace the defrost thermostat.
Posted on Dec 31, 2010
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
Jul 18, 2013 | Scotsman HD22B-C0322MA-1B Hotel / Motel...
Deli case icing up at evaporator inlet
Most deli units are gravity cooling units and it is normal for the evaporator to be iced up if your unit has fans it still is not unusual, the ice will melt when the unit cycles off. If the evaporator is only iced up on one end, you are low on freon.
Feb 26, 2013 | True Deli-Cases TSID-48-2-L Refrigerator
Kenmore AC, no cold air
If the evaporator tube is iced up entering the coil and cool to warm leaving the evaporator, that would indicate low on refrigerant or a restriction. If it is iced up entering and leaving the evaporator, then, it could be low on refrigerant,blower not running at proper speed, dirty evaporator coil or filter.
You need to check the suction and head pressure and temperature to determine problem for sure.
Jun 07, 2010 | LG LWHD1200FR Wall/Window Air Conditioner
Unusual noise and ice all over the freezer
This sounds like the fan is hitting the ice. If it's iced up, remove the food from the freezer and place in refrigerator.
Take the bottom panel out of the inside of the freezer section and then remove the back panel from inside the freezer section. You will then be able to see the evaporator fan. You will need to check to see if the evaporator fan will turn with the power of the refrigerator turned on.
You also want to look to see if the evaporator fan is turning and hitting ice which means the evaporator is froze up. You will need to check and see if the evaporator fan is bad or the defrost timer is bad.
Oct 17, 2009 | Refrigerators
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Sep 06, 2009 | Sub-Zero 561 / F
ICE MAKER WORKS BUT WILL NOT DISPENSE ICE
That happens because the evaporator system that is supposed to heat up ice cubes to release it is faulty. Have the ice maker evaporator system tested and eventually replaced.
Apr 18, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
Everest Refrigeration ESR2 Logo
125 people viewed this question
Top Everest Refrigeration Refrigerators Experts
mike cooper
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
