I have a Patton C8538R Door Chime that I need a part for. The cover that covers the top of the chime and electronics. Can you find this for me??? Thank You Ron
emissionwiz
  • 78919 Answers
SOURCE: warning chime disconnect
You will have to disconnect the warning chime module, it is on the driver side under the dash, follow the sound, it is about the size of a pack of smokes, it is usually black in colour.
Posted on Oct 29, 2008
  • 16 Answers
SOURCE: Chime always "dings"
take fuse out
Posted on Mar 12, 2009
  • 31 Answers
SOURCE: Remote doorbell not chiming.
I would recommend replacing the battery in the remote button. There may be enough battery power to light the light, but it usually takes a bit more to transmit the signal to the main unit.
Posted on Apr 19, 2009
  • 82 Answers
SOURCE: "Headlights on" warning chime not sounding when I open car door.
I had the same problem as this...
When you open or close your door there is lever that sits just below the the door latch that is attached to the frame of your car by a single screw.
It is a black plastic L shaped bit of plastics that slides on its own guide. It has obviously started to malfunction over time.
To double check this:
Turn the car lights on
Open your door
Locate the black L shaped plastic level.
Wriggle it around sliding back and forth - if it starts to work when you are applying pressure onto it it looks like it has broken.
Go to your local wreckers and ask them for a replacement part (it cost me $2.00 AUD to get mine)
To take the part off all you need to do is push the level back as far as it will go and you will see a phillips heads screw holding it in place.
Undo the screw and detach the part (there will be a wire attached to the back of the metal guide)
Unplug the wire and throw the part into the bin.
Attach the wire to the back of the new part and screw the new one into place.
All should be working fine now.
Good Luck
Posted on Mar 09, 2010
Testimonial: "Thank you for helping. That did it!"
SOURCE: my door bell chime chimes all the time even if all
Pull the chime out.
Posted on May 26, 2010
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
2004 trailblazer where is the door chime fuse?
No separate fuse for the chimes, runs on direct battery power as a safety measure. Only way to disable it is to find the "chime box" and unplug it. Usually under the glove box area.
Jun 03, 2014 | 2004 Chevrolet TrailBlazer
D641/BLR DOOR CHIME CHANGE CHANNELS
Open the back of the door chime and the button press.
On the back of both of them there is a set of jumpers.
From left to right there are 6 available frequencies. You need to grab to jumpers to join 2 of the pins together (top and bottom pin). If you don't have a jumper just use a set of pliers and cross the 2 pins together (top and bottom pins) on a channel you wish to use. Repeat the process for the button press if you've just done the door chime. The 2 pins that you've joined together needs to be the same as you've just done for the door chime.
Note the red jumper on the button press, selects the type of door chime you want to hear. this is the 4 right hand side pins on the button press. The far right is a long chime and second in from the far right is a shorter chime.
Hope this helps, figured it out by trial and error. :)
Sep 19, 2012 | Bell Cocoon Child Carrier
How do you stop / turn off an 89 Mustang chime / buzzer?
If You Are Talking About The Door Chime There Are Two Ways To Do It One Is To Simply Unplug the Chime Two Is To Remove The Steering Columm cover and Unplug the black wire that is going to the side of the key switch I would Recommend This Method Because Unpluging The Chime Its Self Will Disable the Headlight on Switch off Warning As Well Removing The wire From Switch on column will disable key in switch door open only
Aug 17, 2009 | 1989 Ford Mustang
THERE IS A BEEPING NOISE THAT STARTS AFTER DRIVING IN MY 2000
Here are the warnings:
The generic electronic module (GEM) controls the following warnings and chimes:
  • Driver safety belt not fastened (warning lamp and repetitive chime).
  • Key-in-ignition (repetitive chime).
  • Headlamp-on warning (repetitive chime).
  • Door ajar (warning lamp and single tone).
The following four distinct chime rates are used to indicate warning:
  • Seat belt warning chime is one chime per second.
  • Key-in-ignition warning is two chimes per second.
  • Headlamp-on warning is four chimes per second.
  • Door ajar warning is a single chime.
please rate as solved if this is what you needed.
May 19, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Ignition alarm will not stop 97 ford f150
The key switch usually breaks or wears out and makes contact. It is on the lock cylinder. This would cause the chime to not come on, or stay on. Sounds like the switch is bad.
1997 F-150/250 Warning Chime, Key-In-Ignition The key-in-ignition chime warns that the key is still in the ignition when the driver's door is ajar. The key-in-ignition warning chime will sound when:
  • GEM: Driver door is ajar, the ignition switch is in the OFF/LOCK or ACC position and the keys are in the ignition.
  • CTM: Driver door is ajar, the ignition switch is in the OFF/LOCK, ACC or RUN position and the keys are in the ignition.
The key-in-ignition warning chime will stop sounding when:
  • Driver door is closed.
  • Key is removed from the ignition.
  • GEM: Ignition switch is switched to the RUN position.
The key-in-ignition warning chime inputs are:
  • Ignition switch RUN position (battery potential on both RUN and RUN/ACC inputs).
  • Ignition switch ACC position (battery potential on RUN/ACC input only).
  • Key-in-ignition switch (grounded with key-in-ignition, open circuit with key-out).
  • LH door ajar switch (open circuit with door closed, grounded with door ajar).
This is a pic for a 98, could not find one for 97 which may be the older style which is more prone to break.
Feb 14, 2009 | 1998 Ford F150 Regular Cab
Chime goes off
Open the drivers door and look at the hindge area and you will see a black rubber accordian tube between the door and the pillar.This is the protective cover for the wiring harness. Now take a screw driver and stick it into the latch that latches when u close the door and trip the latch. Now start up the vehicle and wiggle the black tube and see if you can duplicate the concern. If so then pull the cover back and inspect the wires for a broken wire. these models are bad for this happening.
Feb 03, 2009 | 2001 Ford Explorer Sport
I want to get rid of the stupid door chime.
That door chime was driving me crazy too. It turned out to be really easy to pull the power cord from the chime. If you fold down the glove box by pulling the two plugs out from the inside, you can see the chime up behind the dash just to the left of the glove box. Just pull out the cord attached by removing the clip and you are golden.
Ahhhh. Sweet relief. I have been chime free in my accent for 2 months, and it makes for a much more enjoyable car.
Enjoy!
Dec 27, 2008 | 2008 Hyundai Accent
How do I adjust the Chime Level on an ADB340MP?
pull off the front cover of chime unit and turn down the volum control knob
Dec 16, 2008 | Clarion ABD340MP AM/FM CD/MP3/cassette...
137 people viewed this question
 Grubhead
Grubhead
