Question about ASUS Eee PC 1000H Laptop
I have to hold the keys down for a couples seconds on my EeePC asus laptop in order for it to type. Did I press something that locked a keyboard delay?
    President:
  • 1,082 Answers
You might have activated Sticky Keys or more likely Filter keys feature, used for some types of special assistive access.
Open your Ease of access control from the control panel and read up.
Try holding down the Right Shift key for 8 seconds and see if it clears.
Posted on Dec 31, 2010
Jumbled keyboard numbers
Are you typing on your laptop and notice the text has become illegible? What should be letters, have become numbers or symbols. This odd behavior can probably be explained be peering a little closer at your keyboard. Those little numbers on the keys. These numbers and symbols normally become active when you hold down the function key, usually labeled as the "FN" key. The "FN" key is similar to the Shift key, activating a second function assigned to a key. It can become active seemingly on it's own because a key is locked in the on position.
Before performing numerous key combinations, try the simple thing of lightly tapping the "FN" or "Num Lock" 5 to 6 times. There may be a small particle of something logged under the key that you can loosen, move, or crush down. Do not bang the keys, just press normally. Next focus on the "Numlock" key which usually located with the "Print Screen" and "Pause" key on the top right of your keyboard. Press the "Numlock" key, then press a scrambled key to see if it's normal. Older model laptops may require you hold down at the same time, the "Ctrl-Shift-Numlock" keys. Newer models may require holding down the "Shift" key and pressing the "Numlock" key. Turn off the Function key with the following combinations. Hold down the "FN" key and hit the "Numlock", Hold down the "FN" key and hit the "Scroll" key and Hold down at the same time "Fn+F12+Num Lock"
Feb 08, 2013 | Lenovo Computers & Internet
Tip
FIXED keyboard stuck in fn mode ...
keyboard stuck in fn mode ASUS eeePc .. what you have to do is press and hold the Fn key, then while holding the Fn key, press Num LK or Number Lock key, That should fix it. Good luck!
on Feb 10, 2010 | Computers & Internet
Keyboard numbers are jumbled
I have an asus eeepc seashell series and i turned it on and it says reboot and select proper boot device and i dont know what that means or how to do it
Power laptop, when asus logo is seen, look down bottom right, press F12 or the number assigned for your model, use the arrows up down keys on the laptop keyboard, highlight hard drive and press enter, this will set the boot order for your hardware to start.
Jun 15, 2012 | ASUS Eee PC Seashell 1005HAMU17PI PC...
Where is the "tm" symbol
There is no "tm" symbol key on a keyboard, you need to enter an ALT key to type the trademark symbol.
Hold down the "ALT" key while typing 0153 and it will enter this: ™ when you release the ALT key
Mar 04, 2011 | ASUS Eee 4G Notebook
I have an Asus X58L laptop, For some reason there is a letters lock and I do not know how to unlock it. So if I press letter u it gives me 4, if I press p it gives me - and so on, unless I press Fn button
It sounds like you have the num lock switched on, most laptop keyboards are too small to have a separate numeric keypad so use the letter keys on the right side of the keyboard for this. (you should note numbers as well as the expected letters on the face of these keys).
To turn off the num lock, hold down the Fn key and press Ins. (located top right of the keyboard).
Jun 27, 2010 | ASUS Laptop Keyboard for Asus Eee PC
FIXED keyboard stuck in fn mode ASUS 1000h eee
thats a good one for people with long fingers!
Feb 10, 2010 | ASUS Eee PC 1000H Laptop
Connect tv to eeepc 701sd
hold down the keys for a few seconds ,make sure you havent pressed Fn-F1 in error as this will put the eeepc into suspend/sleep mode
Feb 01, 2010 | ASUS Eee PC 701 Notebook
Asus laptop keyboard problem
Your numlock is on. Press the Fn key and find the key that has num lock or num on it written in blue, usually around the i key or the 8 key and press it while holding down the Fn key.
Jun 21, 2008 | Computers & Internet
ASUS keyboard
u have problem with ur key board remove the dust in the key board its not problem with ur computer its a just ur keyboard
Oct 18, 2007 | ASUS Premium Vista M2N32-SLI (M2N32-SLI...
ASUS Eee PC 1000H Laptop Logo
298 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
