Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
Computer will not boot. The CPU fan runs wide open and nothing will post.
    Master:
    Sergeant:
  • 381 Answers
Most likely a video card problem / motherboard problem or memory problem
i would suggest start with the easiest and the cost effective one.
take out ram, power on, power off, install ram.
reboot.
Posted on Dec 31, 2010
Computer freezes randomly
If you have a fan that is not running, it can cause the system to run hot and freeze or shut down. Maybe that fan only turns on at a certain temperature so open the case and run the computer and keep an eye on the fan to see if it ever turns on. If not, replace it.
You probably need to apply a fresh coat of Thermal Paste around the CPU and Heat Sink. If it has dried up or is too thin to keep the unit cool it will cause the system to freeze, run hot or not be able to boot. Remove the screws from the fan that sits on top of the cpu and heat sink, then remove the heat sink, then unlatch the handle on the side that holds the cpu in the bay and remove the cpu (remember how it goes back into the bay). Clean off the old thermal paste then put the cpu back into the bay, secure it by closing the latch. Apply a fresh coat of Thermal Paste on the CPU, clean the old thermal paste off the heat sink and apply a fresh coat of Thermal Paste to it. Put everything back together.
Boot the computer up then download and install MalwareBytes and run a Quick Scan to see if you have a virus or infection.
Go to www.google.com and in the search box type: "Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
Jun 03, 2012 | Computers & Internet
Computer won't boot
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 26, 2012 | Computers & Internet
I'm having an aspire m5640. it does not boot. beep?
Yes if there are error on the system you should most likely hear a beep most of the time when there is no beep it is due to bad ram. Some times beep codes can't detect bad ram and your computer will not boot.
Open the computer up and see how many ram chips you have if you have more than one take the one in dimm slot 2 out. There should be small writing next to the slots 1,2,3,4 or Dim 1 dim 2 ect ect. you always want to keep slot 1 with ram so start by pulling out the ram out of slot 2 and turn your computer on. If your computer still dosn't post pull the ram out of slot 1 out and insert the ram that was in slot 2 into slot 1 if still no luck it's most likely your board but the best way to test this is to know that you have a good working stick of ram you could purchase one and if it dosnt work bring it back ... theres also the chance of your video card being bad but there is usualy a post code for it (beep code)
if you have no clue on what ram looks or how to open your computer just google for installing ram on a computer and you should find step by step guides
Jun 02, 2010 | Acer Aspire m5640 PC Desktop
I was running a virus check, asked what to do, I said fix, computer shut down and alarm buzzer came on. now I don't get a boot sound
soks3d,
With the system shut down, unplug the power cable from the power supply. Open you're case and pull the memory from the system wait a minute than reseat the memory. Re-connect the power cable to the power supply. Try booting the system and enter the bios menu. (Pulling the memory will clear any memory resident virus). This has nothing to do with the alarm buzzer sound you heard. Typically the alarm sound is generated by the CPU. It's an audible warning that the CPU is over-heating. The CPU will shut down you're system so as not to damage the motherboard and CPU. (Suggest you check the CPU fan for dust build-up. Use canned air to help remove any build-up. You can also use a clean paint brush to help remove any dust from under each CPU fan blade.
It's also possible that the CPU fan is running far too slow and may need to be replaced.
See page 3-23 in you're user manual.
3-8. PC Health Status.
Open the link provided below for a new heat-sink and fan assembly for a socket 462;
http://www.directron.com/a4004d.html
If the CPU fan and heat-sink assembly seems clean it is also possible that the thermal grease / thermal tape between the heat-sink and CPU is too old and needs to be replaced. (Save this check for last).
Below is the link for you're motherboard;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=KV7-V&fMTYPE=Socket+A
Cheers'
Mike
Feb 20, 2010 | Abit KV7-V Motherboard
Gateway gt4016 won't boot. Fan runs but nothing
open cpu cabinet and pull Ram and refix it.
Aslo reattcha llconnection to mother bord.
Pull cmos cell for 15 minutes so all bios setings are set to defaults.
Jun 12, 2009 | Gateway GT4016 Desktop PC
My Screen is blank and fan continuously runs.
your computer is not posting that is why you do not hear a beep. This can happen for 1 of 10000000 reasons but I would start with checking the RAM then all the other hardware to find a loose connection/dead hardware.
May 28, 2009 | Compaq (203966-001) Motherboard
Will not boot
plug the cpu fan tightly and try again it might be overheating.
Jan 07, 2009 | Intel (5184-0062) Processor Board
Computer does not boot (new Machine)
Swap the power supply since you got two systems?
Feb 23, 2008 | Pine Technology XFX NFORCE LT 680I SLI...
Intel Media Series Intel G33 chipset micro atx no post no boot after crazy fan
make sure you have seated all the cards properly, take them out and reseat them including the ram. Make sure your IDE cables are plugged in properly as well.
Restart the computer and if still no post then yes unfortunatly for you its the mobo =(
Dec 03, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
217 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
