Question about Maytag MAH6700AWW Neptune Front-Load Washer
Need a new washer door - Maytag MAH6700AWW Neptune Front-Load Washer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Here is a link to the door parts for your machine.
Posted on Dec 31, 2010
How do i replace a stack washer dryer dryer door switch?
when you open washer door you hit a stopper pin that holds the door open. there are 2 screws located around that area on both sides of panel. remove them and you'll see vent hook up and water line hook up and power cord. Now at the backside of washer door panel there are two screws remove them and pull washer door panel towards you. under the door panel connected to panel is where you will find door switch. if you jump out door switch and it works then you need new door switch.
Apr 30, 2014 | Whirlpool Thin Twin Washer and Electric...
Door repairs
The doors have a pin and washers that help keep the door functioning right. There is a kit they sell at your local auto parts store for about 10. bucks with new washers and a pin. More than likely the washers are broken and need to be replaced. Its a fairly easy job. Just cut off the clamp at the bottom of the pin push it out and placethe old washers with new washers then place in the new pin with the c clamp at the end.
Jan 26, 2013 | 1991 Ford Thunderbird
Frigidaire Affinity ATF7000 installed new door switch now says cd
The main control board thinks the door switch circuit is "open" - you would need a professional to . Is the loading door closed? No, close the door. Yes, go to step (2). 2. Disconnect the plug from J2 on the Main Control Board and check for continuity between the pins in the plug. Open, check the door strike. If good, replace the door switch assembly. Closed, replace the Main Control Board.
Aug 22, 2012 | Frigidaire Affinity ATF7000E Front Load...
Door lock sencor not working properyl
You probably need to fit a new door handle spring, and or a new door catch.
You will need to undo all the screws that hold the 2 halves of the door together and seperate the 2 halves of the door.
Then you will be able to see the problem, and repair as repair as req'd.
May 09, 2010 | Hotpoint WMA54 Front Load Washer
The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
Oct 19, 2009 | Frigidaire FTF2140FS Front Load Washer /...
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
Door spring on washer
Is posible that you need to remouve the door to instal the spring and then instal the door back.
Aug 12, 2009 | Whirlpool AWM6120 Front Load Washer
Bosch WFK 2401 Need to slam door several times to lock door
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Jan 24, 2009 | Bosch Classixx WFL 2462 Front Load Washer
I need to fit a new door seal
easy fix love what you need to do is un-plug the washer now tak the 2screws from the back of the washer that holds the top(lid) in place now open the door and around the edge of the door seal there will be a spring wire pull this out so you can unattach the door seal totally from the washer front the seal will still be attached to the inner drum though now stand up and look down through the top of the washer down to the front were your door seal is still attached to the washer there will be another clamp with a screw on it undue the screw but you dont have to undue it totally though pull the clamp out through the front through the door seal now will come off the washer now just do these instructions backwards to re-fit the new door seal let me know how you go on or if you get into trouble doing the job peter
Jun 10, 2008 | Hotpoint Aquarius WD640 Front Load...
Maytag MAH6700AWW Neptune Front-Load Washer Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
