Question about HP Photosmart Premium C309A All-In-One Printer
I can no longer get a wireless connection. The wireless network test report indicates that the wireless radio is not functioning. The radio indicator light is on. When I try to do a wireless setup, the printer is unable to find a network. Is there any fix that I can do?
    Novelist:
  • 119 Answers
Hi
Try the following steps:
1. Connect the power cord of the printer directly to the wall jack (make sure its not connected to surge protector.
2. Turn the printer On, Press the "Setup" Button, go to "Network", then go to "Restore network defaults", press "Ok" on that.
3. Printer would ask you if you want to restore or not, select "Yes"
4. After that in the same menu (Network Menu), go to wireless test report and print it.
5. If it still shows that the wireless radio is not functioning then only move to next step.
6. Press and hold * and # together on the numeric keypad of the computer.
7. Printer would ask you for a special key combo, enter 1, 2 and 3 respectively.
8. It would open the support menu. Press ok on that.
9. Then scroll to resets menu, select "Semiful Reset"
10. Once you would press ok on this, the printer would go off.
11. Wait for 2 minutes and then turn the printer "On"
I hope this would resolve the issue that you're facing.
All the best!!
Regards
Posted on Dec 31, 2010
Testimonial: "Thanks. I'm back up and running but I'm curious as to what the surge protector has to do with it?"
  • Upvansh Mehta
    Upvansh Mehta Jan 16, 2011
    Well generally surge protector is unable to supply the amount of electricity that a printer requires to run its complete mechanism.
    Well good to hear that your printer is working.
    Happy Printing!!
    Happy New Year!
  • 1,218 Answers
Your wireless printer might frequently lose its communication with the computer and hence might not print all the documents when you want. Such an issue arises when there is interference in the wireless signals between the printer and the computer. This could be caused by any other wireless device kept in the vicinity of your printer like a cordless phone. Keep all other wireless devices way from the printer set-up to tackle this issue. Also bear in mind that if your system is turned on for hibernation mode then it would disconnect your printer the moment it goes into hibernation.
Posted on Jan 27, 2011
How do I find the Printer IP address
Test the wireless connection
Print the wireless test report for information about the printer wireless connection. The wireless test report provides information about the printer status, hardware (MAC) address, and IP address. If the printer is connected to a network, the test report displays details about the network settings.
To print the wireless test report
1. From the printer control panel, touch (Wireless), and then touch Settings.
2. Touch Print Reports
3. Touch Print Wireless Test Report.
Apr 09, 2016 | HP Officejet Pro 8610 Wireless All-in-One...
Why does the network report indicate that I have a channel conflict?
it could be possible that a Wi Fi from someone else (a neighbour ) is using the same channel. Change the channel used in the Wi Fi router to a different channel number. Also any other radio equipment on 2.4 Ghz could interfere like a cordless phone system in your home if on 2.4 Ghz 802.11 n or 5 Ghz if 802.11AC .
Aug 03, 2015 | Epson Workforce 610 All-In-One InkJet...
Wireless assistant
hi, try to download win wireless driver on the p c
Jun 18, 2017 | ASUS Computers & Internet
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
Jan 17, 2013 | Pantech Pocket
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
I have an HP309a which I bought just over a year ago. The wireless printing has stopped working with the network test report stating 'the wireless radio is not functioning, contact HP support' Does anyone...
found that clicking to Setup ' Network ' Wireless Radio and then manually turning the radio OFF then back to ON solved the issue. if this does not fix the problem please respond with solution that resolved yours as my sister is currently attempting to resolve issue on her laptop with printer radio not working.. thank you
Nov 15, 2010 | HP Photosmart Premium C309A All-In-One...
How do i set up my hp laptop to wifi
Please Understand wireless network settings and setup:
Wireless networks depend on special-purpose radio receivers and transmitters that substitute the exchange of messages over the air for the exchange of messages that occurs over wired connections on conventional networks. When you power on your PC, Windows Vista automatically searches for available wireless networks.
The network icon in the system tray, shown in Figure 1, enables you to view a list of local networks that Windows Vista detects. Notice that the network icon in this figure is marked with a red X, which indicates no network connection is currently established.
Figure 1: A red X indicates no network connection is active.
When you click this icon, a window opens indicating you're not connected to a wireless network, as shown in Figure 2.
hpsmb_laptoppcwireless-fg02.jpg Figure 2: The detail window for the network icon provides a link to create a network connection. The window also includes two hyperlinks: Connect to a network and Network and Sharing Center. Click the Connect to a network link to open the Connect to a network window, shown in Figure 3.
hpsmb_laptoppcwireless-fg03.jpg Figure 3: Connect to a network window.
Nov 10, 2010 | Computers & Internet
My HP 309 series printer will not stay connected to my wireless network. Can someone help? I end up having to go through wireless network wizard all over again with my WEP password. Very time consuming!
Hello geekgurl !
There are a few things you have to check
When choosing a location for your wireless router, avoid having the following items between the wireless router and wireless devices on the network: long distances, walls, other wireless devices (like cordless phones), and large appliances.
Don't use two wireless routers in your home unless you are very knowledgeable about wireless networking. If your Internet Service Provider (ISP) provides your wireless router as part of their equipment, don't add another wireless router to it or attempt to change the existing settings without the ISP's help or knowledge.
Make the following settings on your wireless router, or verify that they've already been made:
1-Change the manufacturer's default name for the network name (SSID) to something unique.
2-Set the broadcast SSID to "on" or "enable". Note that "on" or "enable" is typically the default setting.
On the printer:
1- See if the wireless indicator lamp is illuminated. Can you turn on the wireless radio from the control panel of the printer?
* Does the Wireless Network Test report indicate trouble?
* Do the reports indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
* Compare the printer's IP address to the gateway IP address. They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
* On some printers, the Network Configuration Page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
* Are there several networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
* Make sure your computer is not connected through a VPN (Virtual Private Network). You cannot access devices on your wireless network while connected to a VPN.
* Disable your operating system's firewall and your security system's firewall and re-test. If this fixes the problem open ports in the firewall.
HP's Network Diagnostic Utility can also be useful
Visit this link
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-926&h_lang=en&h_client=s-h-e013-1&h_keyword=dg-NDU&jumpid=ex_r4155/en/hho/ipg/easy_wireless/network_diag/
Check if theres anyway to set an Static IP (does not change) on your printer instead of a Dynamic Hp (constantly changes)
Good Luck !
Aug 13, 2010 | Office Equipment & Supplies
Lost Wireless Network Adapter
check the driver status on device manager, if your wireless adapter is indicated there are not
Nov 10, 2008 | HP Compaq nx7300 Notebook
NO WIRELESS CONNECTION
I am aboutsure about the question, but what i understood is wireless switch location
First close your laptop, then look the front view where the speaker is located, From the left
1.Speakers Left and right speakers deliver stereo audio
output.
2 Power indicator Lights up when the computer is on.
3 Battery indicator Lights up when the battery is being charged
4 Bluetooth communication
button/indicator (for
selected models)
Press to enable/disable the Bluetooth
function. Indicates the status of Bluetooth
communication (optional).
5 Wireless communication
button/indicator
Press to enable/disable the wireless function.
Indicates the status of wireless LAN
6 Line-in jack Accepts audio line-in devices (e.g., audio CD
player, stereo walkman).
7 Mic-in jack Accepts inputs from external microphones.
So your wireless switch is the 5th one from the left. Locate it and turn on the wireless, and try to connet to the router.
Try this, hope it may work,
Jan 27, 2008 | Acer Aspire 3000 Notebook
HP Photosmart Premium C309A  All-In-One Printer Logo
3,150 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
