Question about Singer 3116 Simple
When sewing sometimes the thread knots up down by the bobbin(I have a singer machine)...what am I doing wrong?
    Genius:
  • 1,788 Answers
Could be a lot of things but it usually your top theading. On this machine I use a metal SA 156 bobbin and have no jamming, but that is my preference. For your threading, totally rethread, now with the presser foot up, pull your top thread, it should feed smoothly, then put the presser foot down, now pull the thread, it should barely move. This usually seats the thread in the tension discs. You should have had a dvd to show you how to operate your machine in your manual bag. Also, study your manual. If, you are trying to sew on sheer or lightweight fabric, use a stabilizer of some sort, (gift tissue paper or printer paper works also).
Posted on Jan 01, 2011
Somethings wrong with the bobbin, it knots up on the back of material
try these suggestions
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Apr 15, 2013 | Singer 3116 Simple
Haven't had the Singer Sew Simple very long. Second time to use it. Ready to throw it out the window. Bobbin tension seems to be off. Thread keeps knotting up and breaking under fabric, jamming the...
Have you tried re-threading it? Remember to keep the presser foot up as you thread so that the tension discs are open. Re-thread the upper thread because it can often cause bobbin jams.
Perhaps your tension discs are blocked, try running a thicker thread through by hand to clean them.
Check there are no broken threads in the bobbin raceway.
Sometimes the wrong size needle upsets the tension.
Sep 15, 2011 | Singer 3116 Simple
My machine is a singer 2259 tradition my machine is making knots, i can sew two points and then it s totally locked aqnd won t work any more because it's full of knots
Machine threaded incorrectly. Insufficient tension on upper thread. Bobbin case spring broken. Lint clogging thread path. Bobbin wound incorrectly.
Jun 05, 2011 | Sewing Machines
I have a singer touch and sew and the bobbin keeps knotting up when i sew. what could be the problem/
You may have tangled thread or the bobbin not threaded right. Totally rethread your machine according to your manual. If, you do not have your manual handy, download one for free at singerco.com. Good luck
Sep 12, 2010 | Singer Touch Sew 7462 Mechanical Sewing...
Singer 301a sewing machine does not sew for more than 2 secs...top thread just knots into a huge ball on bottom of fabric...everything is threaded correctly and all tension set well...next step is trash...
Recheck the top thread and bobbin tension for equal balance of thread when sewing. The knotting of thread problem is usually because the tensions are too tight or too loose and/or thread may not be properly threaded. Another reason is when the bobbin thread is wind imbalanced it will cause the thread to knot-up when sewing. This problem is notorious when the bobbin is winded within the bobbin case on some machines. The bobbin thread need to be wind smoothly in the bobbin to avoid this problem.
Jan 24, 2010 | Singer Sewing Machines
I purchased singer bobbins to use in my singer 5050. I thread the machine and bobbin per manual instructions, but when sewing, the thread severely bunchens and knots up on the bottom side of the item I'm...
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Sep 30, 2009 | Singer 5050 Mechanical Sewing Machine
Problems with Singer 2732
Jan 02, 2009 | Singer 2732 Mechanical Sewing Machine
Singer 6412- thread loops up and knots up on bottom of material
Good luck ..
Dec 31, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 5525 sewing machine knots up thread on underside of fabric after three stitches
most commonly this is from incorrect threading top thread. Check manual for threading path or follow threading path usually marked by arrows on machine
Sep 10, 2008 | Singer 8280 Mechanical Sewing Machine
Singer 3116 Simple Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
