Question about Saeco Royal Professional Espresso Machine
I have a Saeco Royal Professional. My problem is that the cappucinatore is not sucking up the milk. We've rinsed it with water and it still doesn't **** up the milk.
  • 1,089 Answers
HI
If you still have the pin in the top of the cappuccinator, try twisting it when the cap. is steaming. Twist slowly until it starts to draw milk up the tube. If you don't have the pin that is the problem.
There is a flat side on the shaft of the pin that causes the suction when the steam passes the pin. If you don't have the pin you can get any suction.
Posted on Dec 31, 2010
Can I descale my expresso Royal by using water and vinegar
Yes you can vinegar' as long as you rinse it well with destiled water to rinse good.
Sep 12, 2012 | Saeco Royal Professional Espresso Machine
Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Aug 02, 2011 | Saeco Royal Professional Espresso Machine
Cappucinatore don't work. I should have steam comming out of the pipe on left side, pump is working,steam come out from front but not side?
HI That is a stuck solenoid. Try pushing the cap.button on and off about 10 times and see if the solenoid can be freed.
Feb 15, 2010 | Saeco Royal Professional Espresso Machine
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Jul 09, 2009 | Saeco Royal Professional Espresso Machine
I have anew royal professional the milk throther,
Aren't you supposed to foam the milk in a seperate container with the steam wand?
Jul 02, 2009 | Saeco Royal Cappuccino Espresso Machine
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Feb 21, 2009 | Saeco Royal Professional Espresso Machine
Saeco cappuccinatore
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Jun 10, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal -No water is coming out of milk frother and water underneath machine
Yes- specially if you see "white scaling around it". If machine not regularly descaled, this can happen. For part and or customer support contact
Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 04, 2008 | Saeco Royal Professional Espresso Machine
Capucinatore problem?
Try programming the cappucinatore button. First try holding it down for about 20 seconds while steaming. See if it will steam for 20 seconds after that without holding the button down.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Dec 15, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal coffee machine
There is probably something wrong with the milk frother. I would purchase a new one before having the machine serviced.
http://cerinicoffee.com/cappunicatore_Royal_white.asp
Apr 30, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
173 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
