Question about Frigidaire Ovens
I have a frigidaire m/n PLES389ECD and the burners and oven aren't working and had the error code f20, the clock timer was replaced but now the clock is the only thing working the burners and oven still do not work.
Ihave a frigiare cook top stove and i cannot get my other 3 burners to come on, i have replaced my control board and one burner switch and i have checked the wiring hanness
Posted on Mar 18, 2015
  • Frigidaire Master
  • 8,220 Answers
The ESEC system and the electronic oven control ain't communicating. Check the wiring connections between the oven control and the esec controls. The thang is designed to lockout the top burners while the self clean feature is in use. If you failed to reconnect that connection which feeds back to the ESEC I imagine nothing does work. LOL. here's a video which shows how it works and I have the manual loaded on Gdocs fo you.
30 Inch Freestanding Electric Ranges_Rev A (5995438461).pdf (4 megs) printable.
I have a frigidaire m/n PLES389ECD and the burners - themobilian_633.jpg
Posted on Dec 31, 2010
Frigidaire oven and broiler stopped working but clock andtop burners work
Hello Friend, this is Z. I am happy to assist you!
I see that both the clock and burners of your Frigidaire range are working but your oven does not bake or broil. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? With this information I can better address the issue at hand.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you!
Sep 06, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is not working its 5 years frigdare electronic elements are ok
Try setting clock before presuming board is faulty, ovens shouldn't work if clock is flashing or timer is counting down or bell symbol flashing. Consult your instructions
warmest regards
Richard The Repairman
Mar 29, 2014 | Frigidaire FEB30S5D Electric Single Oven
F20 error code on Frigidare electric range
Hello rjshomesnj - Typically error code E20 indicates that the range has detected a communication failure between EOC (electronic oven control) and ESEC system (electronic service element control). In other words, the range has an issue with the switch for the burner. I will personally recommend contacting a certified technician to move forward accurately and to assist with the repairs. You can often locate qualified servicers by visiting the manufacturer website.
Mar 01, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F10
Hello,the F10 error code means "Runaway temperature"most likely the problem is bad Electronic oven Control ("clock/timer").it has to be replaced together with the overlay because it's glued to the clock.
Thanks
Jun 01, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Frigidai #RG35HW*1 , the oven won't come on, not on bake, broil, preheat, nothing. But everything else works, the burners, the light, the clock/timmer. Just not the oven. Is it something simple...
evene thought he clock timer is functioning it may still be bad and not operate the oven or broiler.this should be replaced they can cost up to 140.00 dollars.also check to make sure that the elements are good if they are good then they clocktimer does need to be replaced
Feb 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Feb 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Control panel on oven not working (clock/heat time, etc..) (model fgf326a)
HI, this control(clock/timer), will need to be replaced at this time. this code represent a control fault within the chip set(logic). this control has failed.
Jun 01, 2009 | Frigidaire FGB24S5A Gas Single Oven
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Ovens Logo
229 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
