Question about Mitsubishi WD-62525 62" Rear Projection HDTV
I have a mitsubishi wd-62525 and I just changed the lamp in it and now all my setting are gone I tried to reset but it did not work do I have to program the tv over again?
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
This model has two resets, not the reset button on the front of the set.
The soft reset is with the original remote, and the set on hit menu, 1,2,3 enter.
This will reset the set to the condition it was when new in the box, yes any labels or other things will be gone and you will have to reset them.
If this does not work you now have a real problem.
let me know if you have questions.
SD TECH also available on Yahoo
Posted on Dec 31, 2010
Testimonial: "Response time was great and the advice worked! Awesome site!!!"
  • coryn607 Jan 06, 2011
    Thanks it worked! I had no idea that there was a reset button on the remote! Thanks so much!
WD-62525 wont turn on after replacing lamp
After replacing the lamp, the lamp time should be reset. Do this.
Jan 29, 2013 | Mitsubishi WD-62525 62" Rear Projection...
My Mitsubishi tv model wd-62525 not on the light of timer is linking
If one light is blinking (lamp light?) remove and inspect lamp to make sure it is in correctly and not shattered. If the set has a recessed reset button on front (if set is unplugged and plugged back it should blink green for about 70 seconds and go out) you may have a issue there.
The model indicated here has a host of problems.
May 20, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Won't work after replacing lamp
Ballast board might need to be replaced,it is what powers Lamp on. Go to Encompass Parts Distrubtion they will list Parts/Prices for this Set.1-800-638-3328
Mar 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I too have a Mitsubishi 62525 with steady blinking green light.
IF YOU UNPLUG SET THE LIGHT WILL BLINK FOR 45 SEC WHEN IT STOP YOU CAN PLAY SET ,IF THIS NOT WORKING CHECK THE LAMP
Aug 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Lamp
remove the lower front panel by pulling it off thenyou will see the lamp compatment on the left front behind that panel. Very easy to replace.
Jan 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV WD-62525
Could be quite a few things wrong. first I would do self test diagnosis and see what error you get, then check that area. It could be a bad Ballast or it could be Fuse F9a09 and the Light Engine. It also could be Caps C9a37 and C9a38. For additional info www.ctechnicians.com
Dec 10, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
964 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
