Question about Whirlpool Dishwashers
Model ADP6000WH/ADP6000IX - HOW TO ADJUST THE TOP SHELF
3 Suggested Answers
SOURCE: my dishwasher is coming up
I just had the same thing, same model. After cleaning the filter out, the problem remained. I then read on another forum that it helps if you tilt the machine backwards for a few minutes (which involved pulling it out of the cavity in the kitchen). Did this and it now seems to be working. Hope this helps you.
Posted on Aug 13, 2010
heatman101
  • 43501 Answers
SOURCE: ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My
Hi, Yes, it will keep water hot but most dishwasher require you to hook to the hot water so that the water is hot when it comes into the dishwasher and then the heating element just maintains the temperature...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Posted on Sep 30, 2010
Model ADP6000WH/ADP6000IX. What is error 2?
if this is a model that flashes the clean light in blinking code for faults , then your not properly reading the flashing light , if it repeats the two - two flash rate this is an indication that its lost its communication between its internal circuit boards (most times this is a logic board problem ) but it can be the other ones as well or ive even seen a wet cable do this as well , if the flash rate is 1 flash - two flash this is an indication that there is stuck key on the keyboard (or a cable problem too )
but the Number one problem I see with dishwashers is there's water(or had been) where it should not be !! water in the wrong spot causes all sort of gremlins to show up and it doesn't take much just one drop and its chaos
Apr 13, 2016 | Whirlpool Dishwashers
Our whirlpool dishwasher make ADP6000WH/ADP6000IX runs for the first few minutes of each cycle the just kind of pauses and will not finish the cycle
Check your FLOAT... When it stops, Open the Door and see the Water LEVEL.
If the Water LEVEL is normal, then you have a problem with your Circuit Board
Apr 09, 2013 | Dishwashers
Whirlpool adp6000ix not cleaning properly
I would suggest getting a de calcifying agent and putting the washer through several cycles. Sounds like the dump valve may be getting plugged up.
Sep 06, 2012 | Whirlpool Dishwashers
ADP6000WH/ADP6000IX--Whirlpool Dishwasher.(new) My problem--Water not getting hot--i have it connected to the cold water--should it heat the water ?
9d561c5b-7c7e-4515-8a01-fbfa8f762c34.jpgerror 3 not heating..on wix6000 /or / ADP6000WH
same boards .
rip out the the main mother board with all the black boxes ,and the transformer on it,,there is 1 black box its the biggest of them all ,next to the fuse with the blue cover on it ,with care take the black cover off with a screw driver carefully, not to damage the lower half of the internals,the lower section must not be damaged all ,once the cover is off you will see a copper coil on one side and on the other a set of breaker points ,at the end of the points ,get a screw driver and push in the outter point inward just a fraction,and bingo it will work again,of coarse its a temp solution,you will need to get a new breaker box from tandy or dick smith or simlar place to keep it going long term ..
hope this helps guys and gals ,please take extream caution when working on such dangerous power sourses ,and always make sure the power cord is removed before and repairs or tweeks..
cheers
Sep 30, 2010 | Whirlpool Dishwashers
My dishwasher is coming up with a error 4. my dishwasher is a whirlpool ADP6000WH/ADP6000IX please help
Aug 05, 2010 | Whirlpool Dishwashers
Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
May 21, 2010 | Dishwashers
What does it mean whirlpool adp6000wh err 4 message code
Error 4 means" too much inlet water", turn inlet water tap down.
Aug 25, 2009 | Whirlpool Dishwashers
All food on top shelf of refrigeratr is freezing
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 17, 2009 | Refrigerators
Whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Jan 15, 2009 | Dishwashers
Dishwashers Logo
69 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
