I cant find my pass word to allow another to use my wi-fi
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    What is the make and model of your router?
  • 33 Answers
You will have to reset it to factory default
Posted on Dec 31, 2010
  • John Mar 07, 2011
    To reset router to default there is always a reset button either on the back side panel or bottom of the router use a toothpick or something small to be able to push the pin in. Once you are ready to go unplug the router from the its power source, then wait about 25 seconds the power it back on, then push and hold the reset button for about 15 seconds. This should remove the existing password you forgot and set the router to default. I hope that this assisted you. Thanks for using FixYa John
I can't get it to go on my wi-fi. Help!
1st pass, go into the settings (the gear icon) amd make sure that wi-fi is turned on. I don't recall mine doing that but that was a couple of tablets (several years) ago.
2nd pass, if the wi-fi is on, make sure it is seeing your wi-fi hub (router).
3rd pass, if the wi-fi is on and you can log into the router with another machine (like a laptop or smart phone) then it's time to get it replaced and hope the warranty is still in effect. If the warranty has expired, go onto ebay or Amazon and get a real tablet. iRulu was my first tablet and I consider it to have been a piece of junk. Definitely not worth even the small price I paid for it.
Sep 22, 2016 | Irulu 7" Google Android 4.0 Capacitive...
Cant get the wifi to turn on
Hi Melissa, So you tried turning your tablet off then on.... If still no Wi-Fi and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a slide switch there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..https://www.youtube.com/watch?v=8XurHgNoZhs
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 21, 2016 | Tablets & eReaders
How do I find my Wi-Fi passcode
Whoever set up your Wi-Fi should know that. Same passcode should work for any device on your Wi-Fi network.
Apr 08, 2016 | Amazon Kindle
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Cant acess my wi fi on my kindle fire as it needs my parental password which i cant rember
Not positive but think you will have to unregister the Kindle and then re-register it. You will lose everything.
Mar 09, 2014 | Amazon Kindle Fire HD
Can't pick up wireless networks
Simple Troubleshooting for the Wireless:
1. Check WI FI must ON
2. It should display the WI FI SSID address3
3. If you are unable to see that the it will be the issue of wi fi
4. If WI FI address is showing then click on it and then it will ask for pass key
Oct 04, 2013 | Acer Computers & Internet
How do i get my sprint phone to work on wi-fi ?
sprint phone or samsung ?
Sprint offers high-speed WiFi service for existing Nextel customers, and provides an extensive network of hotspots in the United States at locations commonly frequented by business travelers, such as hotels, airports and conference centers.
Getting Sprint WiFi requires a Nextel customer account, connection-management software, a MyNextel user account and a computer that supports high-speed broadband.
Sprint WiFi plans include an unlimited WiFi hotspot and an unlimited PC access plan with a WiFi hotspot package.
Sign up for WiFi service through Nextel by calling 1-800-SPRINT1.
Download and install the Nextel Connection Manager software.
Nextel offers the WiFi version of the connection-management software at the Sprint Nextel website (see Resources).
Register your account via MyNextel on the Sprint Nextel website (see Below).
http://ortshop.sprint.com/en/solutions/dataaccess/connection_manager.shtml
Samsung Epic 4G Phone into a Wi-Fi Hotspot
The Samsung Epic 4G smart phone allows you to convert your phone into a Wi-Fi hotspot and connect up to five devices.
Such a set-up will keep you from running around searching for an area that offers free Wi-FI. If you're stuck in an airport or staying overnight at a hotel, you won't have to pay extra for Internet service.
You can connect your laptop or other media device to your phone's Wi-Fi network.
Press the "Home" button, which looks like the outline of a house, on the bottom of your Samsung Epic 4G phone.
Click the "Menu" button to the left of the "Home" button.
Click the "Settings" icon, which looks like a gray box with a spoke in the middle.
Scroll through the list and click "Wireless & Networks."
Press "4G" until a check mark appears, indicating the 4G network is enabled.
Click the "Home" button.
The 4G icon will appear to the left of your signal bars in the upper-right corner of your screen.
The separate sets of bars above the 4G logo indicate the strength of your 4G signal.
When the bars above the 4G logo are completely gray and the 4G logo is white, you have a weak signal.
When you are no longer receiving a 4G signal, your 4G logo will be gray and a 3G logo will appear, indicating that the 3G network is now enabled. If both of the logos disappear, you are not receiving any signal.
You must have either a 3G or a 4G signal to use your phone as a Wi-Fi hotspot.
Enable Sprint Hotspot
Press the "Applications" icon, a blue box with four whites squares in it, in the lower-right corner of your Samsung Epic 4G phone.
Press the "Sprint Hotspot" icon, which looks like a phone with two signal bars on the right side, until a check mark appears to the right of the icon, signaling the Spring hotspot function is enabled.
A pass-key allowing you to connect other devices to the phone's network will appear on the screen.
Write the pass-key down.
Enable Wi-Fi on your laptop or other device that you want to tether to your Samsung Epic 4G phone.
Search for the Wi-Fi network affiliated with your Samsung Epic 4G phone.
The name of the network will begin with "SPH-D700XXX."
To change the name of the Wi-Fi network affiliated with your Samsung Epic 4G phone, press the "Menu" button; the "Settings" icon; and "Device Name." Enter the new name for phone's Wi-Fi network.
Click the network affiliated with your Samsung Epic 4G phone on the device you want to tether to your phone'ss Wi-Fii network.
Enter the pass-key, and click "OK."
Your device will now be tethered to the Wi-Fi hotspot on your Samsung Epic 4G phone.
Aug 06, 2013 | Eforcity For Sprint Samsung Moment M900...
How can i connect wi fi to this phone
go to settings, select " Wireless & Networks "
select "Wi-fi" ( It will turn the Wi-fi on )
after the "Wi-fi" is on, then select "Wi-fi settings"
then you will see some Wi-fi networks.
then select the wi-fi networks you know, and depend on the security of the Wi-fi, you sometime have to enter the pass key to get in to the network.
hope it helps.
Jan 24, 2012 | TvShows Android Apps
Decoder description wep wpa psk to work to overide wi-fi system
ok, WEP, WPA and PSK are all wi-fi security protocols. They are designed to restrict access to your wi-fi. I would not by pass them.
Nov 11, 2011 | Zyxel P660HW-D1 Router
Samsung sch-i730 cant access wi-fi
To acces the internet have you tried:
START
PROGRAMS
INTERNET EXPLORER
For Wi-Fi:
START
SETTINGS
Wi-Fi
Tap red bar to switch from Wi-Fi Disable to Wi-Fi Enabled.
Apr 10, 2009 | Samsung SCH-i730 Pocket PC
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
