Question about Coleman Quickpump
I have a coleman quickpump, but after camping this past summer my grandkids misplaced the part that you attach to the quick pump to pump up the air mattress. Is that particular piece available without buying a new pump? You can contact me at the following email. rwcbuild@yahoo.com Thank you in advance Rod Werner Phone 715-573-2232
    President:
  • 1,514 Answers
The part can be bought from coleman's website at http://www.coleman.com/coleman/parts/ProductImage2.asp?product_id=5999B400
Posted on Dec 31, 2010
How to use pump to deflate air mattress
There is an intake port and an exhuast port on your Coleman quick pump. To determine and differentiate you need to turn it on and the one that is blowing air out is the exhaust that you would use to inflate the mattress. That leaves you with one other orifice that is taking air into the pump body. If you put your finger over that one it will suck down like a vacuum cleaner hose. That is the one that you want to attach the plastic adaptor nozzle to, and then hold the nozzle on the fill port of the air mattress. It will come down and into a vacuum state when it is all the way exhausted. Once completely deflated, they are much easier to fold back up and stow away. If you're at home and own a vacuum cleaner with a hose, save the batteries on your pump and use the vacuum cleaner. It will take about thirty seconds with that. Good luck with that.
Dec 29, 2015 | Coleman Quickpump
How to inflate when camping with no electricity
Purchase a manual pump or a 12 volt pump that plugs into your cigarette lighter. Make sure your cigarette lighter works before you leave on your trip. There are also battery operated pumps.
Jun 05, 2014 | Coleman Camping 2000009831 AeroBed Premier...
Need parts
If there is no nearby repair dept, try Colemn.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
Mar 31, 2013 | Coleman Vintage Bernzomatic Deluxe Propane...
What is the recommended stove for summer backpacking?
The recommended stove for summer backpacking is a canister or an integrated stove system.
Sep 10, 2012 | Coleman Camping, Backpacking & Hiking
Is my old Coleman QuickPump 5999-200C compatable with new Quickbeds?
If the new bed has a built in pump, you won't need the old pump. If not then you can use your pump on the new bed. It all depends on the model you choose to replace your old one.
Aug 05, 2012 | Coleman Quickpump
My coleman 424 stove has been sitting in shed for a coulpe of years, now got it out again. Filled with petrol when pumped up I can light it but flame only lasts a few minutes then it dies as if no...
My best answer is that your pump seals have dried out and are allowing pumped up pressure to leak back past the pump seal
Try this: DO NOT LIGHT THE STOVE
Pump it up hard then quickly attach a small balloon with a rubber band around the base of the pump - where it contacts the tank. A deflated balloon or a small plastic baggie - does the balloon begin to fill with air after a few minutes - if yes then your seal is leaking.
You might try taking the pump apart and soaking the seal overnight in fuel reinstall and see if it cores your problem
Good Luck
Mar 22, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
Coleman rechargeable Quickpump has stopped working. It was dropped and the black wire broke off of the charging receptacle in the back. When I opened it and touched the black to the terminal it did...
I bought this about a year ago and used it once. Took it out today and it did not work after I charged it all day today. Not sure why or how to fix the problem.
Dec 31, 2009 | Coleman Quickpump
How to use the tire pump tool on the quickpump.
I have the instructions if you send me your e-mail address i will send them to you.
Jul 10, 2009 | Air Tools & Compressors
Backfire problems
If your genset is back firing then it could be carberator, bad ingnition coil, fuel pump, poor compression, which should be at least 100 psi.
May 05, 2009 | Coleman Powermate Powermate 5000W...
Air pump stops blowing air after a few seconds.
Check for good spring tension on the battery connections and make sure the switch isn't coming apart. I had the same problem with 2 different pumps and they both had both issues.
Mar 22, 2009 | Coleman Quickpump
Coleman Quickpump Logo
978 people viewed this question
Top Coleman Cycling Experts
John Egan
John Egan
Are you a Coleman Cycling Expert? Answer questions, earn points and help others
