Question about Maytag MMV4205 Microwave Oven
Have MMV4205BAW18 with a main control relay problem. I am told that I can replace this relay myself provided I can find the part. The part number is w10181450. This is a manufacturers part number. Can you provide a picture of this relay????
  • Maytag Master
  • 9,047 Answers
W10181450 is the part number of the whole circuit board, not just the relay.
That board runs $130.74 and you can order it from the Pros here.
The attached photo shows where the two cook relays (RY01 high power and RY02 low power) are on your circuit board.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can contact us via our site with the numbers on your relay, and we may have one or more available.
Whirlpool / Maytag does not make relays available, one has to get them from third-party suppliers by the relay manufacturer's number.
Or we can repair your control panel assembly for you for $39.95. Details are here.
Let us know if we can help further.
Posted on Jan 02, 2011
  • William Miller
    William Miller Jan 02, 2011
    That photo's small here, so I'd better point out that the two relays are outlined in red.
Relay on main control board stuck open on ge profile pvm1871sm1ss
Replace the main board. Or if you desire replace the relay. The relay has a diagram and voltage that the coil works, take the relay out and test it.
Aug 14, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Kenmor Elite microwave oven, model 721.66460400. The timer no longer work properly, i.e., I cannot set the cooking on button. Where would I find someone to provide parts and perfom work to get...
It sounds like a failed membrane keypad.
On some models, you have to buy a separate keypad.
I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
In other cases, you can replace the whole control panel frame assembly, which comes with a ney keypad already on it. This runs more, but it's much simpler.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays have a lock:
You can find helpful exploded views and order parts from the Sears Parts Direct Web site.
That model number (721.66460400) is not showing up in my search. Please check it again.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Sep 16, 2011 | Kenmore 66469 / 66462 / 66464 Microwave...
I have model # JVM1430WD002. Both the under light & ventilation fan are not working. When I press the button, I can hear a click but nothing comes on.
Sounds to me like you main control board is failing. The relays on the board that control the light and fan are closing but the points in the relay are probably burnt and not making contact. You will probably need to replace the main control board. Hope that helps.
Aug 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Our panasonic microwave keeps shorting out
It sounds like the power relay on the main control is shutting down. To fix this problem you would need to replace the control (Mother board). Before doing that the magnetron (heat element) should be tested to make sure that it is not what caused the relay to fail.
If you send me your model number I can try and get a ball part price on the parts you need.
Apr 24, 2010 | Panasonic Microwave Ovens
Turntable not rotating
HI. The most common issue here will be a failed turn table motor. This motor is located beneath the actual table housing. replace this failed motor.
Note(The uncommon problem area will be a failed relay. although, highly uncommon, this may be the issue. i would advise to inspect the motor control relay located on the main control-board for visible burn marks)
Oct 03, 2009 | Hotpoint Microwave Ovens
My Microwave is displaying F6 and running when plugged in.
I found a sheet that says to check wiring to main or microwave relay for shorts. If no shorts found, replace control board.
Apr 10, 2009 | Whirlpool GH7145XF Microwave Oven
Cooktop/Countertop lights will not turn off
Whirlpool told you wrong. Part number is #4158940 is a door switch, but that's not the problem.
They'll sell you parts or refer you to a local servicer, but they won't help you repair your unit.
On this particular model, the solid state relay PH1 near the bottom right corner of the board will be the culprit.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feb 09, 2009 | Whirlpool MH7130XE Microwave Oven
Fans runs when door closed, light always off
The first thing to replace is your technician. *grin*
You have a shorted main relay (lamp relay) on the control circuit board and a burned out light bulb.
You do not need a new board.
Page 24 of your owner's manual shows you how to replace the light bulb. Be sure to unplug it first.
If you don't have your manual, you can download it here.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 13, 2008 | Maytag MMV1153A Microwave Oven
Microwave cooked dinner and now does work
I had the same exact problem -- turned out the cooling fan for the magnetotron wasn't coming on because of a bad relay on the main control board. When the magnetotron overheated a safety kicked on which tripped an internal relay and killed power to the unit. GE repair guy diagnosed and resolved the problem. Only snag was that they didn't have a spare board so I had to wait a few days for them to deliver a replacement and for the guy to come back and install it. Now has been working for 5 days... of course I probably jinxed myself now! :)
Dec 18, 2007 | GE Advantium SCA2001BSS Microwave Oven
Maytag MMV4205 Microwave Oven Logo
112 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
