Question about Mitsubishi WD-52525 52" Rear Projection HDTV
My Mitsubishi tv model number VS 5073 is having a major issue. It works fine when I first turn it on then the picture smooshes together...black on the top and bottom of screen and picture smooshed together in the middle...anyone know why?
4 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Posted on Jul 31, 2007
jerryg50
  • 1689 Answers
SOURCE: PT-51G44
Some of the components in the vertical deflection circuit area, and possibly in some other areas as well, have become thermo sensitive with age and use.
An experienced TV tech can troubleshoot the set to locate the defective parts and change them.
Jerry G.
Posted on May 09, 2008
SOURCE: My panasonic PT-51SX60A has a 2 inch picture loss
tv looks fine then I get just a line in middle and nothing else
Posted on Aug 17, 2010
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
No picture
it sounds like the chassis is bad. there are several ways to take care of this.it just depends on you technical abilities
www.tv-techs.com
Dec 14, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-5046
i have a 50in mitsubishi tv model vs5046 the screen protector is crack the tv works fine but need to know where can i purchase a protector or its there a number. also how much will this cost.
Oct 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Oct 25, 2008 | Mitsubishi VS-60707 60" Rear Projection...
No picture
Are you sure its not a VS60603 ? VS80803 is not a valid model number for mitsubishi. If it is a VS60603 you can get a manual at the following link and they will contact you asking if you would like it emailed instantly. Its 10.99 for the Manual. Heres the link
they have quite a few Mitsubishi as well as other models and they offer free support with the manual.
http://servicemanuals.vstore.ca/
Jan 23, 2008 | Mitsubishi VS-80803 TV
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Tv shuts off
You could have a problem in the sweep or main power supply, Bad capacitors on the DM module, they will be all grouped together and have swollen tops, Coolent fluid leaking out of one of the CRT's. If you have no electronic or solid state repair experience, please get a pro to assist you in this repair. Good Luck
Apr 03, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
