Question about Maax RainForest - Three-Piece Corner Shower Unit with MAAX IES and Door Fra
We have a corner shower with 2 sides against fixed walls. What do you enclose the other 2 sides with?
  • 83 Answers
You can purchase a round shower curtain ring..or enclose with glass
Posted on Dec 31, 2010
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
Adjust frameless glass shower door hinge
The wall was not perfectly plumb before the fixed glass was attached. The top needs to be shimmed out 3/16 and resealed against the wall. On the other hand 3/16 is not much of an error. Maybe no one else will notice it.
Jan 01, 2018 | Cars & Trucks
Tuscany holland tub handheld shower faucet Putting in basemencan the distance between aterspout and shower head be shorten and will 1\2in pvc be ok model #673 7247 phone # 269 651 8920
wouldnt recommend pvc visit your local hardware store for best recommendation i can give you where im not familiar with the setup if it is inside the wall enclosed copper or crimped waterline usually used
Dec 11, 2012 | Home
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
We have a shower surround that is 1/4" thick. However, there is a void of at least 1" from the stud. Where do you mount the valve on the stud? Should it be in the middle or offset? We are...
can you get behind the surround?
Install it in the dead center of your cut out. Use 1x1x3" to support the piping behind your wall of the surround. silicone one side of each 1x1 apply to the wall between pipe and wall then use 1/2" copper "two hole straps/clamps" (any hardware guy will know this when you ask for them.) Use 1/4 - 3/8" drywall screws to fasten the pipe straps to the 1x1's. You'll get your stability when you install your escushtion (beauty ring) on the inside of the shower. Will tighten up against your 1x1's.
You'll see,
Enjoy,
Mike.
Ps. Plz leave a remark.
Dec 31, 2010 | Moen & One Handle Tub & Shower Faucet
We have mould spots in the corner of our downstairs toilet.. started with just a small amount but now have lots. Not a patch of mould but lots of small spots. the room is on the outside corner wall of...
There is probably moisture inside the wall. Take a look at the outside of the wall to see if you can identify the source of dampness. Maybe leaves are piled against the outside of the house, or vines are growing under the siding, or a downspout is splashing against the house when it rains. Or perhaps you have something leaking down inside the wall from upstairs. You will probably need to remove a bit of the wall from inside. If it's drywall, this isn't very hard to do, but start with a small hole, maybe 6 inches across. If you find wet insulation, you should enlarge the hole and remove all of the wet stuff. Before you replace all of the wet stuff with dry stuff, you need to remove the source of the dampness. It could also be that this corner is poorly insulated and gets lots of condensation from the shower. Good luck, Al K
Nov 16, 2010 | Cornerstone Positec Group Ltd No.MM11 Mm...
Installing a stering pivot door
on the pivot side, the seal will go toward the outside,.providing that the seal is on the door,...the seal "on the pivot side of the door" will go up against the wall jamb as you close door,.....
Jun 20, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Assembly instructions for Niagara corner shower encloser
Go to this link and print the pages. original instructions. Good luck.
Feb 21, 2009 | Home
Bottom rail fit on 1500D door in 28" shower stall...
Mark, I'm having different problems with the same door. Try "filing" down the ends of the bottom rail, where it is contacting the curved corners. You might have to buy a metal file to accomplish this. Go heavy on the adhesive caulk on the underside of the bottom rail. Make sure the shower base is clean and dry. You might have to push down with your arms for several minutes to get the adhesive caulk to stick. Good luck, I have to go back to my folks this afternoon, because I can't get the door panel in w/o it scraping the top rail. Ugh.
Jan 22, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Maax RainForest - Three-Piece Corner Shower Unit with MAAX IES and Door Fra Logo
603 people viewed this question
Top Maax Plumbing Experts
Steve
obsteiner
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
