Question about Ovens
Diplomat ADP5330 Range Oven - Ovens
Diplomat elite double oven. No manual.how do I set the clock.
Hello -
Apparently, the Diplomat brand of ovens ended production in 2008.
Prior to the end of production, Diplomat was part of the MFI company, with the company's Hygena brand name combined with Diplomat.
I have not yet found a user manual for Diplomat Elite Double oven online.
However, I have found a Hygena Diplomat manual online (free) and the manual has instructions for the clock. The instructions MAY be the same for your oven (I hope.)
See:
https://productmanuals.inbro.net/seeinsidebrochure/Product-Manuals_Hygena-Diplomat-Select-Ovens/Hygena-Diplomat-Select-Ovens/page_1
The clock instructions are on Page 10: Using Your Electronic Minute Minder.
Best wishes.
Apr 07, 2018 | Ovens
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Identify use of buttons on Diplomat Select 920 double oven.
Try Googling (diplomat)(920)(manual) without parens.
Jan 25, 2018 | Ovens
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Oct 18, 2009 | Belling XOU592 / XOU593 Electric Double...
Setting on knob of diplomat oven
Im pretty sure that settings mean on the 1 line top element only comes on and 2 lines both elements come on hope this helps
Sep 06, 2009 | Ovens
Diplomat ADP3322/3340 oven, temperature markings rubbed off
You can buy the decals from Ovenlettering.co.uk they send you a sketch of the control panel so you know where to place each number.
Aug 29, 2009 | Ovens
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Diplomat Select 620 single oven and no instructions
how do i remove the door to reseal the glass
May 14, 2008 | Ovens
Diplomat Oven ADP3650 Instructions
User manuals are hard to find.
The problem I had was setting the clock on a single Diplomat oven, with no clock button. Here's my solution :
DIPLOMAT OVEN OPERATING INSTRUCTIONS
The Diplomat single oven is controlled by two knobs and a set of buttons along the middle of the control panel.
The left knob sets the temperature of the oven, while the right knob selects the function to be performed, e.g. fan oven, grill, etc.
The buttons along the middle set the cooker clock, the start and end times of cooking, and the “+” and “-“ buttons will increase or decrease the time shown on the cooker’s clock.
PLEASE NOTE THAT THE OVEN WILL NOT OPERATE UNTIL THE CLOCK IS SET.
If there is any interruption to the power supply (including manually switching off at the main switch) the oven will not operate until the clock is reset.
Here’s how to set the clock:
First press simultaneously the first two buttons to the left of the control panel. They are marked as a Bell symbol (Alarm) , and a steaming Cooking Pot (Start of Cooking Time). Then immediately press the plus “+” or minus “-“ buttons to increase or decrease the time displayed. When the desired time has been reached, leave it for a few seconds, and it will remain set at this time. Any further changes to the displayed time will require this procedure to be repeated.
Hope this helps!
Oct 10, 2007 | Ovens
Ovens Logo
3,733 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
