Question about Mr. Coffee IDS77 Electric Burr Grinder
WIll not work at all. Like an internal fuse or switch has gone bad. How do I open bottom and inspect? Is it worth trying to find problem?
I have a Electrolux integrated microwave suddenly stopped working found the internal fuse had gone . Would just replacing this work or is there a bigger fault due to fuse going in the first place .
Fuses blow for a number of different reasons. Here's a partial list:
Bad door switch
Door switch sequencing issue
Weak fuse holder
Problem in high voltage circuit
Mar 02, 2017 | Electrolux Microwave Ovens
Insprion will not do anything
It's very difficult to diagnose from Your description. It would seem that Your power supply has failed but it could be as simple as a defective power switch or a burned out internal fuse. You have to decide how much it would be worth to You to have it working again before You hire a repairman or invest in an upgrade. If You know someone who is handy with tools, You might consider letting them open it up and look for a bad fuse. ****UNPLUG FIRST****
Aug 19, 2014 | Dell Inspiron 15r N5110 Pc Internal...
Car does not turn off after changing fuse
car stays, on, does that mean engine will not shut down.
or mean the wipers stay on, after turning them off
1:yes, wiper, bad internal wiper switch, (bad wiper motor)
2: no:?
wiring hacks (after market installs of something gone worn)
bad igniton switch.
Dec 12, 2013 | Acura Integra Cars & Trucks
Dryer will not start, no noise, nothing
It is as if the door was open right? With the door open the dryer is dead in the water. Closing the door trips a switch. Could be that switch has gone bad. If that turns out to be ok then look for reasons why the dryer would be dead. Take the vent pipe off and inspect for lint buildup. If the vent is blcked and the dryer temp exceeds 350 then the dryer fuse will melt and because it is tied in with the door switch it is as if you opened the door when that fuse melts. How to check it:
Jul 20, 2011 | Dryers
My ASUS VH232H wont turn on, it was working just fine, I tried another power cord that I know is ok & still no power
Chances are the internal power supply has gone bad :^(
If you are capable, you might want to open the monitor and see if there is a fuse and if it is bad (open). If there is a fuse, chances are it is soldered in so ..... you would need soldering skills to replace. You would also need a ohm meter (multi-meter) to test the fuse. Should have zero resistance. High resistance will indicate an open fuse.
Best of luck, Jim
May 01, 2011 | ASUS VH232H 23" Monitor
The monitor screen has gone black. By switching off and then swithing back on a faint image is seen which flikkers and then goes black again.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Computers & Internet
I have G579 miele dishwasher, recently the fuse blows up as soon as i plug in the socket. What is has gone wrong? please advise
Some internal cable damage. Check the main cable and other parts.
If your m/c has electronic switching, the power supply related components need to be checked. Any open the back door and give a visual inspection. Hope no rodent inside damaged the cables!!
Apr 10, 2010 | Dishwashers
Hi i've a question about jvm1630
Yes, there is an internall fuse, but why did the internal fuse blow ? There could be a bigger problem most likely the hi volt capacitor or hi volt diode. These items are worth replacing but caution that there is stored hivolt energy. You first must know how to open the micro to access the control compartment and then actually shot the capacitor terminals to remove any charge. Sometimes it is obvious that the diode and or capacitor has gone bad (they either split or bulge out). The right test er is the best way, or you can replace both pieces if the price is worth it. Goodluck, MAcgivor
Jan 16, 2010 | GE JVM1630 Microwave Oven
Position 5 on my 2002 montana heater control does not work.
I have put up with the same problem until I found a solution today. For me, I believe it was a two part solution:
First, there is a 30 amp fuse (?) located in the passenger side fuse box (next to the door). I believe the fuse was labeled something similar to "HVAC Blower High". Looking at the box, it was the fuse in the very bottom-left position. This is not what I would call a bus fuse so I couldn't tell by looking at it that the fuse was bad. I first tried switching this fuse for the electronic window fuse. I was able to lower the driver's side window so I thought the fuse was good. However, it was not until after I completed step two (below) that I realized that I could not lower the passenger side window from the driver side control. I switched the two fuses back and the window controls worked fine. So, I replaced the suspect fuse and the problem was resolved.
Second, I read online this morning that a bad blower resistor could cause this problem. I also read that the part was fairly easy to replace on this model so I thought it was worth a try. I bought a replacement at my local dealer for $49. To install, I removed the bottom panel from the passenger side (right under the glove box) by pulling down on the three panel "screws". With the panel down, the heater blower was exposed. I found the resistor located just behind the blower. I unplugged the resistor from the blower as well as the wire harness located immediatly on the resistor. I then removed the resistor by removing the three (3) 5/16" bolts. The entire operation took about 20 minutes from open to close. ....the majority of that time was spent trying to get my big fingers around the bolts.
All 5 positions now work. ....Now if I could just resolve the problem with the windows frosting.
Jan 03, 2009 | 2001 Pontiac Montana
Passenger windows wont work
the fuses when you open up the drivers side door towards the top there should be a panel that you can remove to find the fuses but it may also be a relay that has gone bad in the engine compartment fuses and relay bay or the switch for the windows has gone bad try the driver side switch if it doesnt work try  the switchs for the individual windows on there doors.
Sep 03, 2008 | 2002 Dodge Intrepid
Mr. Coffee IDS77 Electric Burr Grinder Logo
144 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
