Question about Relic Glitz ZR11778 Watch for Women
Watch stopped working, thought battery,but put new one in and still doesn't work. There is a small round piece of plastic underneath the battery, does that belong there? I took it out,but still didn't work...Thanks
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Posted on Feb 10, 2009
ansel_albert
  • 248 Answers
SOURCE: The stem pulled completely out of my watch.It
push it inside while you were turning it until you feel something in inside locks, but if not effective, yur watch must be opened to pus the lock inside while you are inserting the stem. if still not effective, your watch module has to be replaced by a new one. i hope this thing will helped you a lot.
Posted on Sep 12, 2011
HOW DO YOU REPLACE A BATTERY ON A CASIO 1572 A168
This is how I replaced the battery on my Casio 1572 A168 watch.
1- Undo the 4 screws to remove the back cover. Note the correct orientation for reassembly by observing the writing.
2- Gently pry out the mechanism.
3- Undo the 6 clips round the circumference of the mechanism with a pin or watchmakers screwdriver. The top half should come loose. There is also a 7th clip which can be more easily unclipped from underneath. Replace the battery.
4- Note the correct position of the small spring. This spring is necessary to make the watch speaker work.
5- Note from the picture the correct position of the special contact which connects with the lower board. If this does not connect properly then the display will disappear.
6- With the battery in place, the watch display should work properly. If there is a problem try connecting the two all clear contacts with a screwdriver, paper clip or small piece of wire to reset the watch.
7- Reassemble the watch and make sure the rubber seal is in place. The seal on my watch was slightly deformed so I used a very small amount of silicone sealant on the tip of a screwdriver to tack it down properly.
8- Put on the back cover being careful not to overtighten the 4 screws and damage the threads. The cover needs to be positioned correctly and not 180 degrees in reverse so the spring will connect with the correct place. When you look at the front and back of the watch the writing should be the same way round.
Kind regards
Chris
*Looking at the picture it might also be possible to replace the battery by removing just the one clip that is closer to the spring. However I found that that clip is more easily undone from underneath, so I preferred to do a more complete dismantling. This also gives more freedom to reposition the battery.
Feb 26, 2013 | Casio A168W Wrist Watch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    New watch - how to start it - battery?
    mcdevito75 here, Brand new watch. If it has a stem, (winder) look for a small piece of plastic between the stem and case, remove this piece of plastic and push down the stem to start your watch. If your watch is all buttons, look for a small plastic tab on the back cover, remove this plastic tab and your watch will start.
    Sep 20, 2010 | Adidas Response Light Twin watch #ADP1701...
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    Hello, this may sound silly but I just bought a Timex Ladies watch and I can set the clock but it's not actually turning on when I push the side button in? It's a new watch direct from Timex so I...
    mcdevito75 here, A brand new Timex quartz watch will come with a small piece of plastic just under the crown to keep the battery form working the watch, simply remove this small piece of plastic from under the stem (winder) push the stem in and your Timex will work. If your timex is push button you may have to hold down the Mode 2--3 seconds to see display.
    Aug 02, 2010 | Timex 27191 Wristwatch
    My watch works with movement, and will work for a few seconds then stop, even thought I'm continously moving. Is it a shortage or something? I can shake the watch and it will work but only for a few...
    I would take it to a watchmaker/jeweler to have them check the battery. Some watches have a battery bar that holds the battery in and it may have come loose. Or the battery is losing charge. It should not cost you anything to have them check the battery for you. Good luck
    Jul 22, 2010 | Anne Klein AK Round Brown Crystals Watch...
    My watch is not working and it is brand new. do
    Look very carefully just under the crown (winder knob) for a piece of plastic used to keep the stem from being all the way down to start the watch. Remove that small piece of plastic, press down the crown and the watch should start. mcdevito75
    May 28, 2010 | Skagen Alarm Function Leather 519XLSL1...
    Indiglo backlight works, but beep/chimes doesn't
    There should be a RESET switch right beside the battery slot. It is usually either the 2 pins that allow the battery cover to hinge up or down, or a metallic strip right beside the hinge. You will see the word RESET underneath the metal strip with a small round metal piece right below it. You need to take a small jewelers screwdriver and push the metal strip down to make contact with the small round metal piece. This will reset everything back to working order. You can then go ahead and set the time, date, etc. Sometimes it is necessary to reseat the battery and do the RESET one or two extra times but it should reset. If after all these steps you still can't get your chimes to work you may have to get your watch looked at.
    Jul 30, 2009 | Timex Expedition 40141 Wristwatch
    I have a Radio controlled watch manaufactured by Crane & Viceroy. I need to fit a new battery.I have bought a new battery and would like to have a go at fitting it as I have never done this before....
    I haven't seen this watch but I suspect the thin metal peice is the battery retainer. If so look carefully to see if it clips over the module at provably several points. If so gently prise them up to release the retainer. Wipe off new battery and install the correct way up. Replace retainer ensure it is correctly clipped in at all points. Set about recalibration process. If it doesn't have clips perhaps it has screws. If so remove them etc. Pleae rate this solution.
    Jul 26, 2009 | Watches
    New watch has stopped
    There are a few possible reasons why your watch is not working:
    1. The battery is dead (sometimes even new watches have a dead or dying battery in them).
    2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
    3. You bought a watch with a damaged movement or somehow damaged the movement through usage and it just will not work period so you may have to return it, exchange it, or have it repaired
    These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
    Jan 13, 2009 | Watches
    Relic Glitz ZR11778 Watch for Women Logo
    43 people viewed this question
    Top Relic Watches Experts
    Ansel Alberto
    Ansel Alberto
    deton8 von Splosion
    Are you a Relic Watch Expert? Answer questions, earn points and help others
