Kenmore 800 ~ used soak cycle ~ cannot empty washer
  • 262 Answers
SOURCE: Kenmore 90 Series Washer has slow spin cycle
yes the clutch is right above the trans mission you have to pull trany and there are pads you can replace them and take scotch brite to the lining try this first if pads look good spray some brake cleaner on the pads they may have grease on them
Posted on Dec 20, 2007
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Posted on Aug 28, 2008
SOURCE: GE washer (wjsr4160gww) makes loud noise during spin cycle
Remove the front panel and you will see two metal guides attached to the front of the frame. One of them will probably be bent and the transmission assembly will have jumped over one or the other of the guides. You need to manually pull it back to center then straighten the bent guide. May have been caused by load being out of balance or machine not properly leveled. Good luck.
Posted on Mar 12, 2009
SOURCE: kenmore washer machine cylce stopped in mid cycle
If your washer doesn't seem to work at all, check these:
  • No power
  • Lid switch
No power
Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
 check these, if still the problem persists then let me know for further help.
Posted on Mar 22, 2009
Clothes still wet after washed
There could still be water in between the drums. Have a look at the filter, pump and all outlet pipes for a blockage. the excees water that you have when you have clothes in will be what's left in the clothes, wih the machine empty you may just be seeing what shows above the inner drum.
Dec 27, 2012 | Kenmore 22422 Top Load Washer
My kenmore fronload washer will not spin out water from cycle. when I opened the door after wash close were soaked and water in maching.
Not knowing the model of your machine, I can provide some generic advice. Please add a comment to this thread if you need more help. This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the left of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Jul 22, 2011 | Kenmore Washing Machines
Whites are not white
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 10, 2009 | Kenmore 44102 Front Load Washer
Gas soaked gloves in washing maching, how can i mitigate the prob
  • set water level to medium
  • add six squirts of dawn
  • run normal cycle
or...
Load up the machine with BABY-OIL SOAKED RAGS and do the fullest....hottest load.
After this - run another hot empty load (with detergent).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washing mchine stops during cycle and starts beeping
See if you are overfilling you machine or the load is out of balance. Even try running the machine empty
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
