Question about Verbatim Computers & Internet
My mac does not recognize the verbatim 1.5tb drive any more. drive is less than two weeks old
    Brigadier General:
  • 10,406 Answers
> less than 2 weeks old
Take it back to where you bought it, and exercise the WARRANTY to get it repaired/replaced.
Posted on Dec 31, 2010
My Verbatim AC320GB 320GB USB 2.0 2.5" External Hard Drive has all of my content from my old PC, now that I want to edit its content on my macbook, I am unable to. help!
It depends on which format the drive is using. If it's FAT-32 you can immediately read and write from it with your Mac. However, if the drive is formatted as NTFS you'll need a third party driver or software in order to write to the drive. Your Mac can read from but not write to NTFS.
Your should be able to read the drive.
Source: reading PC hard drive on my Mac Mac Forums Discussions for Apple Products...
Jan 24, 2015 | Verbatim AC320GB 320GB USB 2.0 2.5 foot...
Verbatim customer service
MACs does not recognise windows NTFS format. So backup the data (if exist) and format drive to FAT32 or ExFAT.
Jul 31, 2014 | Verbatim SmartDisk USB1TB 1 Terabyte 1TB...
It want come up on my computer
Step 1:
Problems with Verbatim portable hard drives vary depending on your model of hard drive, your operating system and your computer hardware. Some problems can include insufficient USB power output, the file system format, and potential overheating due to enclosure materials.
File System b> Verbatim portable hard drives come formatted for use with Mac computers. If you're using it with a Windows or Linux computer, you will need to format it to a file system that your operating system will recognize; Windows computers typically work with NTFS, while modern Linux distributions use ext4. If you have computers with mutliple operating systems, FAT32 is usually considered easier for all operating systems to recognize. Verbatim does not recommend switching a portable drive between PC and Mac computers once you've formatted the drive one way or the other. Adequate Power While most computers supply adequate power with one USB port, older computers can have insufficient power output. If your computer doesn't seem to be powering the drive, use of a Y-shaped USB cable, designed to be plugged into two USB ports, can get more power to run the drive. Additionally, consider trying different USB ports on the same computer; some USB ports get more power than others. Drivers b> Make sure that you have any relevant drivers related to the hard drive that you have purchased. If your drive didn't come with a setup disc, you can check the Verbatim website for product drivers. Overheating b> Of Verbatim's seven portable hard drives, four are enclosed in plastic; of the other three, one is enclosed in aluminum, one in leather, and one in rubber. While all the drives are tested to run well with their enclosure, metal enclosures conduct heat away from the hard drive and help to prevent overheating. Plastic, on the other hand, is an insulator, so plastic enclosures may contribute to heat buildup. Check plastic-enclosed drives for overheating and avoid leaving them plugged in when not in use.
Apr 05, 2013 | Verbatim SmartDisk Firelite Portable USB...
My mac recognizes the verbatim hard drive, then says it was unplugged incorrectly, then recognizes it, then says it was unplugged incorrectly, etc. in a continuous loop. I have purchased two of these hard...
Make sure that you are connected to a usb port on your computer and not thru a usb hub. Also try a different port on your computer. It is unlikely that two hard drives would be bad, but I would try them on another computer. Thanks for using fixya
May 26, 2011 | Verbatim Acclaim 750GB Portable USB 2.0...
I am trying to write files to a terabyte verbatim portable hard drive, but it saids the drive can not be modified. How do I write to the verbatim hard drive on my mac?
Most verbatim drives are formatted to by default to NTFS which is a windows file system. NTFS can be read and copied from on Mac but not written to.
You will need to offload the data to one of your computers and reformat it with the mac.
Apple, Utilities, Disk Utility.
Once formatted for Mac you will be able to read and write to the drive but you will need to add macdisk to the windows PC to allow it to read and write to a Mac formatted disk.
I more information on my FAQ about recovering data from Mac drives on PC
http://www.aitsavemyfiles.com/datarecoverybasics.php?faq_id=6545&category_id=8247
Hope this helps FixYa,
Crankstart
Mar 22, 2010 | Verbatim 500GB USB Desktop 500 GB Hard...
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Jun 12, 2008 | Computers & Internet
Unit does not recognize usb flash drive.
Use a 2GB or less compatible memory card - Sandisk is the best bet.
Feb 19, 2008 | Philips DVDR3575H/37
Computers & Internet Logo
220 people viewed this question
Top Verbatim Computers & Internet Experts
Martin Murray
Arora Singh
Arora Singh
pankaj rautela
pankaj rautela
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
