Question about Meade 494 AutoStar Telescope Control Unit (Handbox only)
Little or no display - Meade 494 AutoStar Telescope Control Unit (Handbox only)
  • 1,027 Answers
That does not help in troubleshooting - can you be more specific?
Posted on Jul 10, 2008
I am losing parts of the little car display inside the car what is the problem
Hi Lottie
The little car display probably has a fractured display cable inside.
The flat copper connectors could be loose.
Someone will need to Remove unit for service
Dec 02, 2015 | Cars & Trucks
Display is upside down
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
Konica machine trouble service c0500 reset
On the right side of display located a display contrast key and a little hole.Under little hole is a reset switch,press the reset switch and wait to apeir * and press 3.
Jan 11, 2014 | Minolta DiALTA Di250 All-In-One Laser...
1. Remove two 7mm hex screws on display panel cover (top, underneith)
2. Put on parking brake, engage key (do not start), move PRNDL lever to L to get out of way.
3. Pull the bottom part of display cover straight toward you (there are 2 clips, one on either side of the steering wheel behind the display assembly cover that will snap free - takes a little force - Do one side at a time) Remove and set aside. This reveals the four display unit screws.
4. Remove the four 7mm screws on the actual display panel. (fyi: all screws in this project are the same headsize, threadsize, and length)
4. Tilt top of display panel toward you and remove the three top connectors (they come out easily and are in a cable harness so you can't put them back wrong) You will need to squeeze the middle gently, unlocking connector and pull)
5. Pull out display - which includes "glass" covering - this never gets removed! (adjust steering wheel to lowest position if needed)
6. On the rear of the panel you will see several (little grey) knobs. Find the one right behind the odometer and using a pliers, twist counter clockwise 1/4 turn and remove. The little light bulb is encased in these little knobs and is included as a one-piece replacement for the $1.50 to $4 bucks.
7. Replace bulb assembly by inserting the bulb and turning clockwise 1/4 turn.
8. Assemble following reverse instruction of above.
May 23, 2013 | 2003 Buick Century
Tv has a little crack and now i have no picture only sound
"a little crack", in the context of plasma displays means totally broken display, which means it's time for a new TV.
Sep 30, 2012 | Samsung 50 in. Plasma TV
Display screen is blank when i am taking pictures
A little more info may be required, if its a canon, after you turn it on look for the little Disp button, press that to cycle through the various display modes. If its not a canon please tell us a little more.
Jan 22, 2010 | Cameras
Little chef in display of Dacor DMT2420 microwave is flashing.
You can get that repaired for $39.95 in most cases (details here) or order a control / display unit here for a little over a hundred.
Oct 23, 2009 | Dacor DMT2420SS Microwave Oven
ISL93.IKSS range hood display flashes "A" and little/no suction
Check to see if your filter is plugged that will slow the air flow.
Oct 02, 2009 | Kitchen Ranges
Optics Logo
134 people viewed this question
Top Meade Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Level 1 Expert
Greg Cann
Greg Cann
Are you a Meade Optic Expert? Answer questions, earn points and help others
