Question about NComputing X300 3 User Expansion Kit Graphic Card
Bad audio - NComputing X300 3 User Expansion Kit Graphic Card
    Scholar:
  • 86 Answers
Not sure what you mean by bad audio. Does it work at first and then the sound deteriorates? Does it not work on any of the stations at all? If you have a dual card setup, does it work on one card and not the other? You might try to upgrade to the latest software, v4.03.104.1. To do so, uninstall any current version of vSpace. Reboot. Make sure you have no missing or conflicting device drivers inside of device manager. Also, while in Device Manager, navigate to the Ports Section and see if there is anything listed for Intel Active Management Technology. It will be listed as IAMT or SOL/COM3. If so, right click it and disable it. Then run the NComputing cleanup utility located here: www.nc-eng.com/tools/ncuninstall.exe. Download current version for XP from here: www.ncomputing.com/download/x300. Unpack the .ZIP file and install. Reboot and register.Do NOT, I repeat, do NOT install from the provided CD and upgrade. Simply install straight from the download file I provided in the link.
Posted on Aug 15, 2011
Scratchy rec audio
Could be several things, controls need cleaning, use contact cleaner, could be bad speaker, replace, caps on audio section need replacement, service with correct components, could be bad audio amp, replace with correct replacement. Not enough info to say for sure
Mar 13, 2014 | Alinco Radio Communications
Car Radio has intermittent audio
bad wiring
if stock ? its not normal
if aftermarket , typical.
can be loose fuse.
or bad connections to the head or amp.
did you lose all sources?
CD/ AUX mp3, radio, am/am, all mode fail?
or just one, this is key to what bad.
if lamps go dead.
or just front or back speakers go dead.
Feb 09, 2014 | 2002 Toyota RAV4
Incoming volume samsung dart
Bad headphones/speakers
It's unlikely your headphones or speakers are bad, but it's worthwhile to eliminate these as the source of your problem at the beginning. Try your iPhone with another set of headphones or speakers just to make sure that the problem is with the iPhone.
Bad audio jack
The most likely cause of audio output problems on iPhone 4S is a bad audio-out jack. If you have determined that the problem does not lie in your external speakers, you should replace the headphone jack.
God bless you
May 23, 2013 | Nokia X2 Mobile
Low audio ,very low audio
Win 7 volume if not on icon tray.
Start > Control Panel > Hardware and Sound > Manage Audio Device> Sound.
Oct 10, 2012 | Computers & Internet
Need driver for Technika 2.1 pc speakers
you should not need drivers for speakers, most like either u have a bad audio driver or a bad audio port. check support.dell.com for the audio driver.
Apr 07, 2012 | Computers & Internet
13" emerson tv has terrible audio. it used to
Bad grounds are common and need to be resoldered. Next you may already have a few bad capacitors that will need replaced. If you can locate the audio output IC, you should check in this area for bad capacitors and bad grounds. 99% of the time a bad ground and bad capacitors will offer you goofy problems in a TV. So take heed and inspect, resolder and replace those capacitors. Thanks for asking and show a few hands of support!
Jan 27, 2011 | Emerson Televison & Video
No sound coming in
Never repaired this one. But that does not mean I can't help you. My first thought is, this TV is being used by kids. You may want to see if there is an object that is stuck in the audio jack, if there is one. And if there is an audio jack, you can almost suspect there is a bad ground on the audio pin jack. That would have to be soldered. There may be a bad ground on a power resistor, a bad ground on the flyback or an open coil. And last note,would be an audio output IC is bad. These are good clues to help you with repairs. Hope this helps and thanks for asking!
Aug 02, 2010 | Emerson SpongeBob SquarePants TV
Legacy audio LA590 car audio amp protecet mode
Is that on all the time or are you saying the light is on? If that light is always on that just means it's protecting your amp. If it's off and not playing bass then your in trouble
Mar 01, 2010 | Legacy Audio American Legacy II LA590 Car...
Sound
Did u have audio before ? If so you might have a blow audio amp. If not it might just be a unplugged cable. This model of tv is bad about bad audio problems mainly a blown speaker and blown audio amp.
Dec 14, 2007 | Philips 42PFL5332D 42 in. LCD Television
No Audio Piture fine
bad speaker,capacitor,or audio output ic, resistor, bad connection,bad headphone jack,bad audio switching ic
Aug 25, 2006 | Samsung TXK2566 25" TV
NComputing X300 3 User Expansion Kit Graphic Card Logo
112 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
