Question about Garden
Hi. I have been seeing Wasps going in and out from behind my Electric Meter Box.They were going in from the Brick Gaps and the Wooden Frame of the Box.I have Blocked all the Holes and have been Swatting all the Wasps that have been coming and trying to Enter.Will this Kill the Wasps that I'm sure are in a Nest in the Wall Cavity behind the Box ?What else can I do as I cannot see The Nest .Thank You.Joe
  • 927 Answers
Go to a hardware store and get Wasp Killer. This stuff shoots in a stream and really kills on contact. Shoot it in there and keep shooting and you should be ok. Shoot it in a safe area to see the stream that I'm talking about.
Gary
Posted on Dec 31, 2010
Why won't my double oven lights or power go on?
I think it would be a good idea to find the electric box and then:
1) find the circuit breaker or fuse that controls the oven.
That information is supposed to be written on the inside of the door of the electrical box.
2) Turn off the circuit breaker, or remove the fuse that is supposed to be the one.
3) Pull the oven out from it's place and try to get behind it to test (with an ohm meter or a multi-meter) and see if the unit is getting electricity at all.
Obviously, you will need to turn the breaker back on or screw in the fuse.
BE CAREFUL, THIS IS DANGEROUS STUFF YOU ARE DOING.
Sounds like you may need to reset the circuit breaker ( that means to turn it off and on a few times) or to replace the fuse.
God bless you in your efforts.
Sep 04, 2015 | Maytag MEW6627B Electric Double Oven
I ***** my electric metre what do i
Not enough information, if you electric meter does not supply any electric it is possibly the company fuse which is about 60 amp to 100 amp, get an electrician.
Sep 07, 2014 | Handley House Miniature Electric Meter...
How do you replace insulation ? It was destroyed by mice. Heater runs so hot top wires melted!
There is very little insulation on top, and to what you may consider as insulation...
the small amount of insulation is used between the header, combustion chamber/box and any wires: thermostat and limit.
if you are referring to wires at top in the front of heater, behind removable front door... Then that is due to (can be considered as insulation as well - as that is what it's supposed to do: Keep the heat in the combustion chamber/box) broken fire tile/brick!
this is common and needs to be replaced.
Call a local service provider , or remove the top assembly to access the Heat Exchanger, disconnect plumbing, then remove the H.E.
You can now see the fire brick, ANY cracks or sacrificed integrity of that brick, need replacement. The heat travels Right THRU that crack!
An easier way to visually inspect brick, would be to disconnect gas line from heater, then remove burner tray. Many wrong installations, Actually NOT To Code, will have a union for the line INSIDE the heater, close to the gas valve. Although this is not to code, it makes for a very simple burner tray removal. Anyway, once burner tray removal is complete, use a mirror and flashlight, and you can inspect brick from bottom.
Link below what that brick kit looks like...
Good Luck
Parts4heating com Teledyne Laars R0325305 Tile Kit 400
Jul 16, 2014 | Teledyne Laars Pool & Spa
Need to mo we an electrical power point in a brick wall in my apartment
More information is needed.
Brick wall is inside apartment... what is on other side of wall?
Open existing electrical box. Drill through back of box and drill through wall until you come out on other side of wall. Install new box #1 on wall where drill comes out. Run conduit over to another new box#2. Drill through wall again until you come out on inside brick wall where you want to relocate original box. Install new surface-mount box#3 on brick wall. Then run wiring from original box. Original box cannot be bricked over or covered with building materials since it is a junction box where wires connect.
Other option is to install extension ring on top of existing electric box. Run conduit across face of brick wall. Install new box#1 where you need outlet.
Other option is to chisel away the brick and mortar from existing electric box down to floor level (or over to door frame). This will allow recessed conduit that can be concealed with matching mortar. Then run conduit across to new location. Cover conduit along floor with baseboard, or chisel out brick along floorline to accommodate conduit, then mortar over conduit. Or simply paint conduit to match brick. You must use conduit since wires cannot be run openly.
Gene
Aug 04, 2013 | Electrical Supplies
Where can I find a wooden automatic gate?
A wooden driveway gate needs to be supplemented with a steel frame to last since they will be opened much more frequently than an ordinary wood gate. The slide type gates will need the structural strength to resist the pulling of the chain. A swing gate, will be cantilevered since a wheel at the opposite end will trigger the obstruction reversing mechanism in the gate operator. This cantilevering over the long width of a driveway requires steel in the structure both to prevent sagging and to keep the gate looking good over time. Gaps and misalignment will occur naturally as the wood shrinks and expands in weather. The steel frame helps to hold everything together tightly.
We make our gates using wood cladding over a steel frame. If you like check out our link at the bottom for more information. Here are some projects we have completed.
http://aaagate.com/wood-iron-gates
Jan 31, 2013 | Home Fencing
We are replacing old doors only in an old house. when we put the hinges on the new door the bottom hinge is slightly misaligned. when we get it put together it binds
Hi this is what I would do. 1.buy a shim pack at any hard ware store (wooden wedges) cheap. 2.take one side of bottom hinge off,frame. 3.shut the door and use shims end to end like this >< Where needed to fit door,some on bottem ,one set on knob side and anoughter set on hinge side.At any rate where ever they are needed to leval the door in the frame. 4.buy some wooden dowels to plug frame holes,might have to drill screw holes larger for dowles.Drive dowels in and break them off. 5.swing bottem hinge in to place and screw hinge down.This should work and you may need a wood chissle or flat screw driver for modifacation where hinges seat.You may have to reseat both hinges or put shim stock behind the frame hinges to line up every thing.I hope something here will help and please feel free to ask any questions that you have and add any thing that will help me see this clearer.You will need a person on both sides of the door to drive the shims togeather to keep the door level. Thank you for choosing FixY.com..................Darryel
Jul 25, 2011 | Homelite ZR10926 16" Chain Saw
Ok , im trying to find out why im useing so much electrity every month , and some one said it might be bleeding through the ground , just checking i seen the only ground goes to the electric meter box out...
The meter at the pole should have a main breaker. At that point the neutral (white wire) will be bonded to the ground and connected to one or more ground rods. from the meter to your mobile home will be an equipment ground that should not be bonded to the neutral in the panel inside your home. The equipment ground from you panel going to the frame is bonding the frame of your home to the equipment ground.
Your large loads will be your Range, Clothes Dryer, Heat, Hot water. A good indicator will be your meter spinning rapidly (the horizontal disc) during heavy use. Turn off all circuits in the home and check that the meter is not spinning. If it is then there is another load other than your home on the service.
Mar 01, 2011 | Hammering
Where is the cabin filter on a 2003 honda odysseey
The cabin filter is located behind the glovebox.
First lower and remove the glovebox
If it has not been changed before, you will need to cut the plastic crossbrace behind the glovebox.
Once out of the way, unbolt the steel reinforcing frame behind the plastic and set it aside.
The cabin filter is mounted vertically behind it.
See images for further explanation:
Feb 26, 2010 | Honda Odyssey Cars & Trucks
The language on the Lexmark printer X9575 is not in English, how do I reset the printer itself to get back to English?
try taking out the power brick off the printer. the power brick is where the power cord plugs in behind the printer - the black box. Then, hold down the cancel and start buttons at the same time (w/o the power brick in the printer yet). Plug in the power brick while still holding the 2 buttons firmly. Printer should turn on automatically. Wait for the language selection prompt. Hope this helps.
Feb 15, 2010 | Lexmark X9575 InkJet Printer
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
