Question about Dryers
No heat from electric element Inglis dryer - Dryers
  • Dryers Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Dec 31, 2010
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
Aug 16, 2014 | Whirlpool Inglis IP8200 Dryer
Inglis Dryer by Whirlpool blows only cold air
check your thermal fuse and your heating element. You'll have to open the back of the dryer, but it's pretty easy to fix.
Dec 19, 2012 | Inglis 6.5 Cu. Ft. 5-Cycle Electric Dryer...
My electric dryer is not heating up
The heating element may have failed or the controller isn't turning it on
Sep 10, 2012 | Inglis 65 Cu Ft 5 Cycle Electric Dryer...
I have an inglis dryer and it's not heating so it appears from online searching to be a fuse problem, We don't have the manual Can I just assume the fuses are in the back and we can easily replace?
If the fuse goes on this dryer it won't run at all. It is located behind the back panel along with the heating element and the cutoff thermostat(located at the top of the heater housing). I would suspect either the element or cutoff, however its not possible for it to be the thermal fuse.
Jan 13, 2011 | Whirlpool Inglis IP8200 Dryer
Inglis electric dryer will not start
Thers's a thermo switch that mounts of side of heating element can may be going bad or your vent is clogged with lint. try running disconnected from exhaust see if it runs normal
Aug 08, 2009 | Dryers
INGLIS DRYER MODEL IP82000 RUNNING BUT NO HEAT.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.(((((Most common issue)))))
Aug 04, 2009 | Whirlpool Inglis IP8200 Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Inglis Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 13, 2007 | Kenmore 63942 Dryer
Dryers Logo
75 people viewed this question
Top Dryers Experts
