Question about Refrigerators
Freezer is running but Fridge part is not. Everythbing is warm and food spoiling
I called a repairman for mine. Turns out the coils were dirty. If you know someone who could check the coils, I'd do that. It took the guy about 5min. to fix it.
Posted on Dec 31, 2010
What are the perfect temperatures settings for the refrigerator section and the freezer section??
PERFECT no such thing . preferred would be a better term . freezer has to be below 0 15 degrees usually and fridge around 35 to 40 . not freezing but not too warm or food will spoil
Jan 10, 2016 | Kenmore Refrigerators
Warm temp. on door of refrig.
The fan on your freezer may have given up thus the cold air inside the fridge doesn't circulate.
Apr 12, 2014 | Whirlpool Refrigerators
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
My GE Refrigerator (GSS25TG) is too cold in the freezer section and too warm in the refrigerator section. Most food is spoiling within a day or so. Any suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 18, 2011 | Refrigerators
Samsung RF267 water tastes terrible. Filters changed twice and not helping
If new plumbing, system is flushing and may cause a bad taste or odd color.Has a food item spoiled?
Make sure that strong smelling food (for example, fish) is wrapped so that it
is airtight.
Clean out your freezer periodically and throw away any spoiled or suspect food. Place foods in airtight containers to prevent the transfer of odors.And also Flush out water hose from tap end to freezer with warm water And also clean fridge with wet cloth (with soap solution). And then clean with dry cloth. .Keep fridge door open after cleaning all compartments for 4hrs minimum, as fresh air could wipe out any bad odor in fridge. And then start using fridge. Hope, it's helpful.
Jan 29, 2011 | Samsung RM255LASH Side by Side...
Have a Whirlpool Gold fridge manufactured in 2000 according to the sticker inside fridge. Same sticker says model# is GT22DA or GT22DC. Freezer is working fine. Fridge part is not keeping food cold and in...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 15, 2009 | Refrigerators
Fridge/Freezer working sometimes. Starts and stops
Need you to check the compressor to see if too hot to touch. If so unplug and don't leave it plugged in until we find the problem. This could be start capacitor, start relay, overload or a bad condenser or evaporator fan motor. Like to know he model number to help you better, Let me know, Sea Breeze
Jul 21, 2009 | Refrigerators
Fridge - with freezer on top
Check the bottom refrigerator door gasket for any possible spilled food or drink that may have leaked onto it. Clean this area with warm soapy water. It may solve your problem. Also check under the drawers and make sure there is nothing there. If there is a drain under the drawers clean it and put some hot water with bleach into it to flush it out.
May 22, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
