Question about Electrolux Heating & Cooling
Air conditioner is not turning on, only power light is flashing when using remote the system beeps but nothing happens
  • 2,133 Answers
Can you see any error code? There are 2 main reasons. 1. Blower motor mechanism locked. Check for bearing and replace or replace motor. 2. Indoor coil and room sensor defective. Replace it. Helpful?
Posted on Dec 31, 2010
Cant get the controller for my fujitsu auy18asd to work with the unit theres no beeping or nothing
An easy way to check the remote is to use a digital camera. Turn the camera on and point the remote at the lens. Look at the camera screen and press a button on the remote. If it is working, you should see the transmitter flash a purple/blue colour. This is not visible with the naked eye so you have to use a digital camera to see it. A phone camera works fine. If you see the transmitter flashing, the remote is probably ok and the receiver board or controller board in the head unit is faulty.
Jun 29, 2014 | Fujitsu 18C1 Air Conditioner
When we turn on the unit with the remote after about 3 minutes it switches off and the timer light flashers then nothing happens
Remove battery from remote for resetting timer. Now you can operate with remote. And also reset your unit power isolating power and re plug it. Thanks.
Dec 30, 2010 | Panasonic CW-1406BU Air Conditioner
We have not used our Daiken wall mounted inverters since the cold days of winter, and now the remote control will turn on the lights, but nothing else goes on and no cool or warm air will come out. The...
Normally, there will be error code whenever the problem arises. But if you couldn't see the error code, depends on counting number of flash, we can diagonize. Any how, with your limited statement, I hereby try to solve your problem.
Indoor Room thermistor error 1time Flashing
Indoor in-piping sensor error 2times flashing
Communication error between in and out 5times Flashing
Indoor Out-Piping sensor error 6times Flashing.
Hope, this helps you.Thanks.
Dec 25, 2010 | Fujitsu Heating & Cooling
Hi, i have 2 daikin air conditioning unit, 1 is working perfectly but when the 2nd is turned on the power light just flashes and nothing happens, any ideas thanks.
The flashes are codes for different problems the unit may have, count the flashes and check your owners manual this will tell you the problem and the solution, or turn the breaker off for 5 minutes and re-start the unit this will reset it the unit should work if the problem start again you will need a service man. hope I was able to help you.
Nov 27, 2009 | Cfm Daikin R410a Split System Air...
Air Conditioner cannot be turned on when power-light is flashing
The flashing light is a delay timer, usually activated when changing from heating to cooling and visa versa. The fact that the unit can only run from certain times shows that the timer is activated. You need to cancel the timer function on the remote.
Nov 19, 2009 | Heating & Cooling
My remote wont turn on A.C. and when I push manual override cool or heat nothing happens the unit is a coleman mach with the RVP remote I am also getting the led flash on 2 seconds off one,my remote test...
If the system does not turn on and there is not beep, it is either a low or overvoltage situation or a problem in the wiring. Check the 12VDC at thermostat and make sure that it is OK. Also, check the incoming 120VAC at the control box (unit with small phone cord)
Jul 06, 2009 | Coleman Mach III Air Conditioner
Air conditioner stopped working
Check the breaker in the panel and the fuses in the disconnect at the outside unit. If that doesn't do it. call a heating and air technician instead of an electrician.
Mar 01, 2009 | Hitachi RAS-09UH Air Conditioner
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Wont turn on just keeps beeping
Hi, I posted the same problem. I unplugged the unit overnight, and now it works. don't know if this will help, but it works!!!! :D
Jul 04, 2008 | Sunpentown SF-610 Portable Air Conditioner
Heating & Cooling Logo
433 people viewed this question
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
