No power for a panasonic pt-52lcx16 52 in. rear projection lcd hdtv
We have been told by a tv repair shop that the main board (part no. LSXA0790) needs to be replaced. They are too busy ad cannot get to it within a month so we are wondering if it is a plug in conncection or a soldered connection and whether or not it would need some kind of 'code' to make it work once installed. Basically, we're wondering if we get the part if we could do it ourselves (we are both electronically capable, but not familiar with the product).
also where would we be able to seure a copy of the repair manual for this unit?
any help would be extremely appreciated.
thanks!
-jamie
My Panasonic TC model PT-52LCX16 has no power.  Any advice?
Posted on Aug 19, 2008
Funny because mine doesn't either as of today? What's up w/ this model TV. I'm really thinking Panasonic was NOT the way to go We've already replaced 2 bulbs....
Posted on Sep 21, 2008
Buy a new tv. it's cost us $700 and 2 tv repair shops and 3 months to fix it.
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Panasonic projection tv pt-53wx52c no picture red light flashing 3 times have sound
3 times red light flashing is an error code that indicates problem in convergence output section, please check and replace convergence output chips and pico fuse nearby. Chips replacement in circuit board requires soldering work and local tv repair shop will help you if you are not familiar with soldering.
Hope this will help.
Thanks.
Mar 28, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic pt-61lcx65 green spot
This may be a main board issue if the green spot moves. This is repairable. This may be a panel issue if it does not move and it is present on the panasonic splash screen and if it affects the osd menu.
Jul 29, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
PT-53TW53 53 in. Rear Projection has sound but no picture
It is. And I hope you some cash set aside for this extremely costly repair.
I once had a rear projection TV and was told by the repairman that each of the 3 flourescent lamps run about $200.00 to replace.
Needless to say I did not get it fixed
Oct 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Dead tv
it needs to be repair its the main power board inside the tv
Apr 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53TW53G 1 Blinking red light, will not stay on.
just got back today for same problem. convergence went out. took to repair shop. $200 part plus $60 labor. second time in a year convergence went out. was told it will happen again.
Mar 19, 2009 | Panasonic PT-53TW53 53" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Televison & Video Logo
447 people viewed this question
Top Televison & Video Experts
Electro Med Services...
