Question about Sony BRAVIA KDL40XBR 40 in. LCD TV
Problems with sony bravia lcd tv kdl 40xbr no digital channels did a all reset but did work but i do get the analogue channels, checked the aerial it is working, what else can i do ????
We had this trouble with our sony bravia, had to get a repair man in to look at it and the digital tuner within the tv went cost $180.00 to have a new digit tuner put in.
Posted on Jan 17, 2011
    Problem Solver:
  • 5 Answers
I am having same issue, and this is what I have learned, so far: Apparently, some of the earlier Bravias (mine is a 2006) has an issue with the F1 and F2 fuses on the Digital Tuner card. I decided to bite the bullet and open up the tv. The back came off fairly easily, and the card is in plain view. I believe it to be the same card that the coaxial connects to. There are two data connectors, top and bottom. after you free the card by undoing the screws, you will want to disconnect the bottom first by simply depressing the center of the connector and gently tugging to disconnect. The top data ribbon is a bit strange... the top of the connector rocks to one side, and the ribbon simply falls out. My card is part number A1164341A and is used on several of the tvs. I found it on Ebay for 10 bucks, inspected and tested. I just bought the card, so I don't know for sure that this is the problem, but I am fairly confident from what i have found out from researching the problem
Posted on Oct 14, 2011
I have my Sony flatscreen (KDL-40XBR) attached to a Panasonic DVD recorder. I recently lost all digital channels on my TV and no digitial channels can be found when I do a full scan. I can still get...
From the looks of it the tuner seems to be malfunctioning. You are able to get picture through your DVD recorder because the signal is directly fed to the audio/video proecessing circuits , when you connect via the HDMI, Component or RCA ports at the back of the tv. Since this mode of connection also ensures better quality signal I suggest that you continue using it as this problem can only be resolved by replacing the main A/V board on which the tuner is located. The board costs about 100-125$ and is not very hard to replace. So if you wish to replace it, then let me know and I will give you the detailed instructions along with the link to the part.
P.S: Bad Rating = No further help.
Aug 15, 2011 | Sony Televison & Video
Hi, I have a Sony Bravia KDL-40D3100 television and recently have encountered a problem. I can no longer view any digital channels. I've tried resetting the television to factory settings and then...
Hi mwaters82,
I have just experienced the same exact problem with the exact same Sony Bravia LCD model. I have just fitted a new aerial in the hope that this would solve my problem but I am still not able to get any digital reception.
Have you managed to work out what was the cause of your problem.
Thanks Simon Mc
Jun 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I have a Sony Bravia KDL-46V2000 LCD television. I was watching a digital program on channel. All of a sudden the screen frooze and I turn to another channel and the screen display no channel allocated. I...
I have the same problem, the only solution I found so far is to disconnect the TV from the mains supply - not very comfortable. The problem seems to happen more and more frequently.
Feb 08, 2011 | Sony KDL-46V2000 46 in. LCD Television
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
My sony Bravia KDL-37P55xx seems to be recieving no signal from our aerial. I know the aerial works as I have checked it with other tvs in the house. Is there a quick fix solution for this
Make sure that the TV is on the right setting, either TV for analog pictures, or DTV for digital. Run a complete auto-setup. This will wipe the tuner memory and re-scan. Hopefully this should sort the problem. If you have tested the aerial cable with another TV in place of that one (not just on a cable from the same aerial in another room) and it works but that one won't, then it will be down to a TV fault. If this helps, please rate me!
Jul 14, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lost digital channels, only getting analogue installed new antenna, no help other sony lcd is working fine
Got to -
Menu -> settings -> set-up menu -. auto start up
Rescan your tv for all channels.
Any more problems, call sony. 08456000124 local rate number
Dec 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Lost all digital channels - Sony KDL-52W3100
Use ur original remote of the tv u want setup to the DTV box go menu switch cable back to air
reseption.Set tv channel 3 hook up the DTV box and rescan the channels u have it.
Aug 15, 2009 | Televison & Video
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA KDL40XBR 40 in. LCD TV Logo
667 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
