Question about GPS
It will not turn on. It was working last night when I went to dinner and when I started for home the screen was black. I tried it in another vehicle, same results.
  • 6,993 Answers
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Posted on Dec 31, 2010
Computer
this sounds like the timer is at fault you may have a dry on the programmer a dry is not making contact to the timer or the bell is on its way out
Nov 03, 2012 | Jenn-Air Ovens
I have a dell m1730 laptop. I turned it off last night before bed, when i got home from doing my running around this afternoon i went to turn on the laptop. The computer turned on, the keyboard lit up,...
Have you tried going to the BIOS? If you can see the BIOS screen there's video and the hard drive could be the issue. If you can't see anything but black screen you probably need to replace screen and or video invertor board.
Jun 28, 2017 | Dell XPS M1730 Laptop
When Window Media Center start up, i get post, then XP Splash Screen, the mouse appears with a black screen. I started recovery to recover to factory default, it seemed to work fine for a week or so, then...
You have PC problem nto monitor problem since you can see the mouse.
Try booting in safe mode (hit F8) while booting up then go to system restore and set it back to the date you remember before the problem started.
Did you installed any new software or updates before this problem started?
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, capacitors, and lamps pictures: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2010 | Gateway 19" Flat Panel LCD Monitor
I don't kno whats wrong with it it was working fine last night. I was using it then the screen went black. Its turn on still but theres no regualr start up or safe mode boot just a black screen.
Can mean alot of things but try removing the battery & and the ram, leave it for sometime and place it back in the system. try run it again.
if not working, try this, remove the Hard drive and boot the laptop without the hard drive or disk. sometimes hard disk causes the system not to display anything on the screen when you switch on.
then you have to get a new hard drive to reinstall the system again.
Aug 19, 2010 | Computers & Internet
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Black spots on the screen
CHANGE OPTICAL UNIT BLOCK COMPLETLY
Jan 30, 2010 | Sony KDF-42WE655 Television
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
Black screen sound ok
Have you tried unplugging the power for a few seconds and plugging it back in?
Aug 28, 2008 | Proscan 19LA25Q 19 in. LCD Television
GPS Logo
182 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
