Question about Frigidaire GLTF2940ES Front Load Washer
Washer model GLTF2940ES3 will not sping - Frigidaire GLTF2940ES Front Load Washer
  • Frigidaire Master
  • 2,605 Answers
Welcome to FixYa.
Based on what you've described, and provided the unit is draining ( and I mean the drum is clear of water aside from the items being soaking wet )...you likely need a door lock/switch assembly.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick & mortar stores or on-line part's depot's such as "searspartsdirect.com" "repairclininc.com" to name a couple. They usually sell for about $50 or so, part # 1531974 ( # at repairclinic.com ) and are relatively easy to replace. It should resemble the image here...
As for replacing said switch, There are a couple ways to access it, through the top and squeezing your arm down the front or the way I prefer, remove the front bellows spring/retainer.
1) **unplug the washer from the wall...safety first of course.**
2) Remove the spring, get it started where the spring is located with a small screwdriver. Once you`ve got the spring/retainer off ( it comes off and on pretty easy by hand ) pull the gasket/bellows back away from the cabinet.
3) Undo the two screws holding the switch to the cabinet, pull the switch out ( there is just enough slack in the wires so don`t pull too hard ) and swap the wires from the old assembly to the nWasher model GLTF2940ES3 will not - 46e20c7.jpgyou`re in business.
4) To put it back together, just reverse the removal procedure. The trickiest part is the retainer. Rap the retainer around the boot leaving the spring for the last...and make sure the spring is located at the 6 o`clock position...usually. Just wherever it was initially.
Let me know if you need further assistance going forward or if my instructions are not clear.
P.S.
There is a slim chance of a faulty motor or motor control board, but that would not be where I would direct you to start...those are exceptions rather than the rule.
Thank you for visiting FixYa today. Good luck.
Regards,
Macmarkus :)
Posted on Dec 31, 2010
  • Frankie Newbold
    Frankie Newbold Jan 18, 2011
    motor and control board probably NOT the problem !!!
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Does whirlppol washer la53coxtwo lid come off
I think on that model you have to get in it from the back side and then look up to remove the screws that hold the lid in place.
Feb 06, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
We have a Frigidaire model GLTF2940ES3 when we press the start water won t come out, it does not give any error just stays there any ideas?
first make sure the water spickets are on. plus there are screen filters where the hoses hook up. take hoses loose and make sure there is no debree.clogging them. make sure water comes out the hoses. hope its that simple.
Sep 07, 2011 | Frigidaire GLTF2940ES Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
What is the best way to approach the problem of the agitator not moving....through the back, top or the bottom?
washer stops in the middle of cycle and says error, and makes humming noise. what could be problem? Model GLTF2940ES3
Feb 11, 2010 | Kenmore Washing Machines
My Fridgidare washer Model #GLTF2940ES3 keeps flashing an "E70" error code. Could someone please tell me what this means?
Hello there :
this 70 code has 2 possible causes
(1) a control board which might be in need of replacement. (costly to replace )
(2) the door lock assembly which could be bad. (fairly cheep and simple to replace ).
I would first shoot for the lesser (least costly of the two) and go with the door lock and this will be the problem if not this controle board can be costly to replace ok ?
I hope that this has helped you out
best regards michael
Oct 22, 2009 | Frigidaire Washing Machines
Wash starts, then stops postin E10 and now soap does not dispense
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
Washer ON and OFF continuously
Error code EB1 is "Incoming power frequency out of limits." Here is a link to various error codes.
http://www.partselect.com/Blog/archive/2008/09/16/frigidaire-appliance-fault-codes.aspx
Jul 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
1,239 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
