FixYa.com
Tags:
iLO -2600 Television
ILO Problem with Cisco Switch
By M0nica L - usenet poster
I have 10 of the new compaq servers that have the Integrated Lights
out Adaptors in them, all of them are plugged into Cisco 2950 Switches
running IOS 12.1.9 EA1. All of the iLO's are running Firmaware 1.15,
and the iLO drivers are either the latest from SSD 6.10 or from 6.00
Every couple of days all of the iLO's drop off of the network, can't
ping ect. I can go to the management agents and reset them, and then
everything works fine. I have hardcoded IP addresses, WINS, DNS ect. I
have also hard set the iLO's to 100/full, but this is still happening.
Compaq Advised me to plug the iLO into something other than the Cisco
Switch. I did this with a crossover cable to a second NIC in another
compaq server and had no problems. Because I had no problems with this
test, Compaq has said that it is not their hardware and that they can
not help me any more.
Please help
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 11, 2005
FixYa! (100)
man1
man1 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Since I do some support work along with my current program workload, I was
wondering, is there some sort of cert or class I can take for problem
denial?
Seth C
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Helpful (85)
Duke
Duke - usenet poster
Rating: 0%, 0 votes
In article <Xns92FF681B13FCAeastburn123 @216.166.71.230>, Marc
<eastburn@<AntiSp@m>speakeasy.­org> says...
Then I would think this is a problem with the mgmt boards.  Or the
drivers for them.  Thanks for the TIP on speakeasy.
hsb
"Somehow I imagined this experience would be more rewarding"  Calvin
***************  USE ROT13 TO SEE MY EMAIL ADDRESS  ****************
Due to the volume of email that I receive, I may not not be able to
reply to emails sent to my account.  Please post a followup instead.
Solution #3
Helpful (85)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Well,
I finally got one of our network folks to look at this, he verified that the
ports were set to portfast and 100/full.
He did mention that he saw some CRC errors and some input errors, but who
knows from when. He cleared the counters and is going to monitor through
tomorrow.
Unfortunately, I do not have access to the switch or the router, I need to
rely on our network team, which up until today has not even taken a look at
the switches in question.
what will the commands that you have listed below show me?
I have not tried to constant ping these mgmt boards but the reason I know
when they go down is that the availability of the device is checked with
SNMP every 10 minutes.
~~Get Speakeasy Broadband - Where the Customer Rules!~~
      http://www.speakeasy.net/refer /36701
Solution #4
Thanks for Trying (70)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Does Cisco support any features that protect the CPU from being
flooded by shutting down a port that receives too much traffic
destined to the CPU?  Or does it support shutting down a port that
receives too many broadcasts (above a threshold)?
Some vendors have features like that that will cause a port to
shutdown based on certain conditions.  It is not always spanning tree
(comment directed at Jonathan).
--Bernie
Solution #5
Mini Me
Mini Me - usenet poster
Rating: 0%, 0 votes
Not necessarily...
The switch might be conned into believing that just that port constitutes a
spanning-tree loop... and shutting it down... and when you reset the
connection on the server, the port goes back into forwarding, until again
receiving the bad bpdu...
See above...
Jonathan
BTW, I may be completely wrong... but spanning-tree is generally the only
thing that will shut down a port...
Check the port's status in the IOS the next time it happens...
Solution #6
Not Rated (0)
Luisa_K
Luisa_K - usenet poster
Rating: 0%, 0 votes
Sure, go here:
http://cgi.cs.wisc.edu/scripts /ballard/bofhserver.pl
Hit reload a bunch of times after you get there...
Jonathan
Solution #7
Not Rated (0)
Lizzy
Lizzy - usenet poster
Rating: 0%, 0 votes
In article <Xns9302741958F9Beastburn123 @216.166.71.230>, Marc
<G>  Maybe they verified it *after* they changed it for you!
hsb
Solution #8
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
Hansang Bae <u @alp.ee.pbz> wrote in
Well that was my original thought, but now I'm not sure. My network guy
finally "Verified" that the ports were set to 100/full and portfast, and
curiously, the Mgmt borads did not go down over the weekend. I'm going to
give it another few days, but since this started happening over a month
ago, they have gone down every 2 days without exception.
My only guess is that the settings were changed on the switch and I was not
told.
Solution #9
Not Rated (0)
Duke
Rating: 0%, 0 votes
We had an SLA with Ameritech (The Big Evil in Illinois...), and every time
you would call them about a line being down, they would put you on hold and
then say "I see nothing wrong..."
And, of course, in that time the circuit came up...
Yeah... uh huh... sure.
Jonathan
Solution #10
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
In article <hlCdnXDMs_gLpYOjXTW @giganews.com>, "Eastburn" <eastburn@
<antisp@m>speakeasy.org> says...
It'll tell you when you last cleared the counters at the bottom.
Always a good idea.
Those Network Bastards! :)
They will tell you if there are any suspect error messages (sho log
buffer 1023), "sho cam dyn mod/port" will tell you what MAC address was
learned or more importantly if it disappears, and - on the router - "sho
ip arp MGMT_IP_HERE" will tell you if the router is losing the arp
table.  Keep an eye on the MAC address as someone may be hijacking the
IP address.
I guess that's often enough.  I just wanted to make sure no one was
falling asleep at the wheels - sorta speak.
How do you like Speakeasy by the way?
hsb
Solution #11
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
Back to my original post  .. this is happening to 10 different devices
plugged into 3 different switches. All 10 are of the same model, we have
other management boards that are different models, and we have no problems
with them at all (they are plugged into the same switches.)
I really hope that I don't have 10 IP's that are getting Hijacked every 2
days.
It's great, a little bit of downtime when I first got it 2 years ago, but
since then very few problems, Static IP's, Installation was painless, I can
(and do) run a private network including servers with the blessing of
speakeasy. I also just upgraded to 1.5/128 service (tested at
dslreports.com at about 1.25/90), it is awesome, I might just bump the
upload speed to 384 in the future.
I also like that you can add to your service from a menu, need a second IP,
great, just buy one, how about dial up, sure buy that too.
Solution #12
Not Rated (0)
herself
herself - usenet poster
Rating: 0%, 0 votes
I am far from an expert but it sounds to me like there is a conflict or
incompatibiliby between the loa and the cisco.  I dont think your test
gets HP (compaq) off the hook.
try pluggin all the ilos in to dumb hubs and the hubs into the switches.
or the ilos into some other brand of switch.
and get back on the phone to HP (compaq) and escalate the problem till you
get to someone that can help you.  dont take NO for an answer.
bill
Solution #13
Not Rated (0)
Janice
Janice - usenet poster
Rating: 0%, 0 votes
"Jonathan" <jrcd @nospam.nospam.hotmail.com> wrote in
It's not actually the NIC in the server it's the Embedded NIC in the
Remote Insight Board (sort of a remote console device) that keeps
dropping, server NIC's are fine (connected to different switch). I'm
running a test right now where I have plugged the Insight board into the
same switch as the servers  .. we will see what happens. Also there are
other servers connected to the same switch as the Insight boards.
Checked out power management ... that's not it.
I also forwaded some information that I found on Cisco's website to the
Network guys here ... Hope they read it.
http://www.cisco.com/warp/publ ic/473/46.html
Solution #14
Not Rated (0)
Mini Me
Rating: 0%, 0 votes
Wouldn't it be cool if it did?
In a broadcast storm, the switches peak utilization and eventually crash...
However, Cisco may have fixed this... hb???
I was just speculating on what would be causing a switch port to disable...
the number one cause would be detecting a spanning-tree loop...
However, I hadn't thought about errdisable...  (which in retrosepect seems
the more likely cause... the odds that the servers were spitting out bpdu's
is remarkably low... But I could conceive MS thowing spanning-tree on their
machines... )
Jonathan
Solution #15
Not Rated (0)
lawyer
lawyer - usenet poster
Rating: 0%, 0 votes
In article
<C69EA17CE0F92982.EB9C97B5359F­C0B4.E16DCD3BF2C1C @lp.airnews.net>,
Ber @weekend.com says...
Nothing for auto-detecting traffic bound for the switch.  But the
broadcast
level can be handled via "set port broadcast mod/port_range 50%" or
whatever percentage you want.
hsb
Solution #16
Not Rated (0)
Pasty
Pasty - usenet poster
Rating: 0%, 0 votes
From what I have read about errDisable, it should change the led on the
port to orange and would also need to be manually reset on the switch, so
simply resetting the end device would not get it back on the network. The
led's for these ports do not go orange, they are green, and the link
light on the device is on.
Is my understanding of errDisable correct?
Solution #17
Not Rated (0)
2Pansy
2Pansy - usenet poster
Rating: 0%, 0 votes
In article <Xns92FE67592DECeastburn123 @216.166.71.230>, Marc
Yes.  So there's nothing in the switch log?  "sho log buffer 1023" ?
It just stops responding?  What does "sho ip arp IP_HERE" say on the
router?  What does "sho cam dyn mod/port" say?  (mod/port of the mgmt
board)  What happens if you ping the mgmt every 5 minutes?
hsb
Solution #18
Not Rated (0)
pandamama
pandamama - usenet poster
Rating: 0%, 0 votes
I would have thought that Compaq would have picked that one up pretty
quick...
It also seems improbable that one would set up power management on the
NICs... most PC/Servers, keep power to the NIC even when the machine is off
(to facilitate WOL)... also to ensure that the switchport is still active so
spanning-tree doesn't prevent logins/bootp/etc... so that you do not need to
enable portfast to maintain network reachability... (this way, if you have
multiple NICs in a Server for fail over (hot standby IP, where both NICs are
up and powered and share a MAC address... I have seen this in clustering
environments) and some idiot enables IP forwarding, you don't accidentally
shut down your network...)
Jonathan
Solution #19
Not Rated (0)
kcw573
kcw573 - usenet poster
Rating: 0%, 0 votes
I'd like to be the one that checks the port settings, unfortunatly, I
dont have access to the switch, I'm having trouble getting our network
engineering team engaged with this. They beleive that this could not be a
problem with the switch, one engineer actually guaranteed that the switch
was not the problem ... I asked for that in writing and he backed off,
but I'm still not getting much help. The only thing that they have done
for me is verify port speed and IOS ...
Right now I have 10 different servers on 3 different switches with this
problem.
Can you point me to an article or config guide from Cisco that explains
this problem so I can forward it to  him and his boss.
Thanks
Marc
Solution #20
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
This is a guess...
There is only one reason a switch port will move from the forwarding to the
blocking state... and that is if it discovers a spanning-tree loop...
But, since we do not know what the switch is actually doing, we can only
guess here... it may actually be a problem with the NICs in your servers...
and Compaq is playing the "it must be someone else's problem, because we
don't know how to fix it..."
Jonathan
Solution #21
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
You really need the assistance of your network guy. Spanning tree would not
normally shut down a port permanently. The switch should have "spanning tree
portfast" enabled so that it starts forwarding as soon as the link comes up
and to eliminate speed/duplex negotiation have it's port fixed at 100M FD.
Solution #22
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
In article <epZS9.152545$iw4.20 @news.easynews.com>,
jrcd @nospam.nospam.hotmail.com says...
Or it could be shut down due to errdisable.  I.e. too many errors on the
port.
Like power management accidently putting the NICs to sleep, for example.
hsb
Solution #23
Not Rated (0)
Rachel007
Rachel007 - usenet poster
Rating: 0%, 0 votes
It sounds like spanning tree is blocking those ports.... So, either the
Compaq's are generating Bpdu's (possible...) indicating a ST loop, or the
network adapters on the Compaqs are shutting down...
Maybe:
On the Cisco Switch ports:
spanning-tree portfast
Solution #24
Not Rated (0)
Mini Me
Rating: 0%, 0 votes
Thanks Jonathan,
One quick question, if Spanning Tree is the culprit, wouldn't it also case
this problem on other devices too.
I have several other devices plugged into the switches and do not have
problems with those.
Thanks again
Marc
Can you Help with these Flat Panel Televisions problems?
problems programming my RCA...
I have a RCA universal remote... Answer This...
REMOTE CONTROL
my remote will change channels... Answer This...
ilo tv/universal remote codes
i need codes for my universal... Answer This...
what universal remote
what universal remote will work... Answer This...
26HD
remote wont work anything but... Answer This...
Repair Service
Find Flat Panel TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
